Question about JVC HD-52G886 52" Rear Projection HDTV
Jvc hd-52g886 wont turn on
I have replaced the lamp and ballast. When you hit the power button the blue light comes on and after a second or two the lamp light starts to flash and the blue light goes out. I have 330v to the ballast board. No power going to the bulb. Any ideas
  • williamsumme
    williamsumme Feb 23, 2012
    When powering on the set the fans also do not run.
    Sergeant:
  • 195 Answers
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Posted on Feb 23, 2012
4 Suggested Answers
SOURCE: hd 52g886
Your Lamp is burned out.
Posted on Sep 07, 2007
BMW Rider
  • 232 Answers
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
Posted on Dec 12, 2007
  • 5 Answers
SOURCE: Last night my JVC HD-52G886 picture turned dark
SRP-9022A main power board is bad, usually the cp9211 fuse is bad on this board. Board runs about $150
Posted on Jan 12, 2010
WHAT IS BALLAST
The Ballast is what powers Lamp On. Follow the leads coming from where Lamp Connects and it will lead you to the Ballast Board.
Oct 01, 2012 | JVC HD-52G886 52" Rear Projection HDTV
Jvc hd ila model hd 52g886 red light blinking, and wont turn on
its due to voltage problem please try to check out the whole power supply track there is a fault in it
Dec 11, 2007 | JVC HD-52G886 52" Rear Projection HDTV
How do i reset my jvc tv
Either a bad lamp or bad reciver board.If audio amp ic on reciver board shorts ,it will kill part of supply and lamp ballast will not turn on and fire lamp.
Dec 28, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Jvc tv
when both the blue light and red light are blinking it means 1 of 3 things. 1. lamp replacement. This often works everytime for the repair. TIP!!! DO NOT USE ANY OTHER LAMPS OTHER THAN JVC AUTHENTIC LAMPS. ANY OTHERS AND YOU RISK DAMAGING YOUR TV FURTHER. 2. the fans are not working properly or need to be replaced. They need to be cleaned every so often and they will stop working from burn-out if not done so. This repair will cost you less than 100 dollars. 3. The ballasts are defective and need to be replaced. The ballasts themselves run about 150 dollars. I tell you I have fixed this TV more times than I care to count, not to mention the number of lamps I have gone through. The guy at the TV repair place now knows me by name when i come to buy lamps. :(
Aug 25, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Blue light in the front blinking no picutre no sound
This is the shutdown code for the lamp ballast. I would have a technician verify ballast is bad and replace. This can be a tricky repair for a novice because installation of the ballast requires that you remove the light engine. Hope this helps.
Mar 28, 2008 | JVC HD-52G886 52" Rear Projection HDTV
TV not turning on
This is the lamp error code. The lamp part# for your unit is
TS-CL110U. Hope this Helps.
Mar 21, 2008 | JVC HD-52G886 52" Rear Projection HDTV
JVC AV56WP74
Replace the lamp, also the shut down time is correct the unit must allow plenty of time proper lamp cooling. otherwise the lamp life will be greatly shortend. normal lamp life is 3000 hrs.
lamp replacement may require an internal limp timer reset have a qualified tech replace the lamp.
Oct 06, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Hd 52g886
Sep 04, 2007 | JVC HD-52G886 52" Rear Projection HDTV
JVC HD-52G886 52" Rear Projection HDTV Logo
109 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
