I HAVE AN OLDER 80000 BTU WESTINGHOUSE OVERHEAD GAS FURNACE IN MY GARAGE. LAST WINTER I HAD A PARTY AND HAD THE FURNACE ON, BUT LATER IN THE NIGHT I NOTICED THE CIRCULATING FAN WAS KICKING ON AND OFF WAY TOO MUCH. THE BURNER WAS LIT BUT THE FAN WOULD RUN ABOUT 10 SECONDS AND SHUT OFF FOR 20 SECONDS AND KEEP REPEATING.I'M GUESSING ONE OF THE LIMIT SWITCHES IS BAD BUT I DON'T KNOW WHICH ONE OR WHERE IT WOULD BE.HELP WOULD BE GREAT!
5 Suggested Answers
JetJedi221
  • 25 Answers
SOURCE: The furnace burners won't stay lit
Could be a couple things. First and easiest is to check your intake combustion air supply. If it is blocked by anything or just not enough flow, it will put out the flame. Next would be the flame sensor, usually a temperature probe near the flame front. If it's not reading an increase in temp within a pre-programmed time, it will kill the flame. It can be checked with a multimeter.
Posted on Jan 25, 2008
SOURCE: Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Posted on Jan 06, 2009
SOURCE: Furnace comes on for 1 min then kicks off, repeats this cycle
MY FURNACE WOULD RUN FOR ABOUT TWO MINUTES , THEN THE BURNER WOULD GO OUT BUT THE BLOWER WOULD CONTINUE TO RUN , LONG ENOUGH TO COOL THE FAN LIMIT SWITCH DOWN , THEN IT WOULD START THE PROCESS ALL OVER. WHAT FIXED MY PROBLEM WAS THE SECONDARY HEAT EXCHANGER THAT IS LOCATED JUST ABOVE MY BLOWER MOTOR WAS PLUGGED WITH DIRT , WHICH RESTRICTED THE AIR FLOW , CAUSING THE FAN LIMIT SWITCH TO REACH 200 DEGREES AND SHUT THE BURNER DOWN . YOU'LL HAVE TO TAKE THE BLOWER MOTOR OUT TO GET TO IT , BUT MY FURNACE IS RUNNING PERFECT NOW
Posted on Jan 11, 2010
SOURCE: 92000 btu Goodman furnace in
Furnace not big enough or poor insulation
Posted on Dec 09, 2010
Not enough heat coming from my Norseman furnace
I suspect the heat exchanger is caked with soot. The type of wood makes a very big difference in keeping them clean. The top cover is removable to access and clean it. No pallet or treated wood to keep it clean. Don't remove any screws you don't have to.
Dec 12, 2013 | Us Stove Company Vogelzang Norseman Add-On...
Mr heater 75000 btu thermostate turned up exhaust air turns on and ignitor doesnt ignite and times out
Probably your ignitor is bad...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 23, 2011 | Mr. Heater Natural Gas Garage Heater -...
I have a Sterling garage furnace,pilot is on ,but main burner will not light.
Be sure you turned the Control knob from Pilot to ON. Without doing that the heater will not turn. If that's not the problem, the Thermopile may need replacing. Also, check the volume of gas at the heater. It should be a minimum of 5 to 7 water column inches. If it has a wall thermostat, be sure the wires are correctly installed at the heater and the wall thermostat and the it's turned up higher than the ambient air temperature in the garage. If this is an older installation, be sure the exhaust vent piping is not blocked.
Feb 09, 2011 | Sterling RF75 Natural Gas Heater (75,000...
I have a 25,000 BTU hanging furnace, will this heat a 900sq foot garage that has been insulated.
Here in Vermont we design heating systems to perform at -10 to -20 degrees. Depending upon how tight the doors and windows are, it may if your temperatures don't drop below 20 degrees. It may take a while to heat up and I would not expect any temperature over 62 degrees inside the garage. Maybe a 50,000 Btu heater? Remember the output may be 20% less than the rated input of the heater.
Dec 29, 2009 | Dayton Gas Furnace Heater
I have a dayton fuel trimmer gass furnace in the garage. the electonic ignitor does not light the furnace. the fan will come on after about 5 min. the number on the name plate is 3e406d
after fussing with the furnace for a couple of weeks of double checking everything i found that the switch for the exhaust was triped. i had checked it 3 times and i thought that it was in the reset position but i found that when i reset it with a pocket screw driver that is was not reset. thanks for the information on your sight.the furnace has ben working for the last 2 weeks with no problem. the dogs will be happy this winter
Nov 17, 2009 | Dayton Gas Furnace Heater
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
Venting a Dayton 4E454 24,000 BTU gas furnace
If you intend to use this in a residential garage, you will have to use standard galvanized round pipe coming off the unit, 24 gauge will suffice, use a minimum of 6”-8” from the unit. From there you will have to make the transition to the B-Vent. Always double check with you local codes in your area.
Hope this helps.
Dec 01, 2008 | Dayton Heating & Cooling
How does heater work to keep freeze off pool in winter
What state do you live in, what is the brand name and model number of the heater. If you live in a state that gets cold during the winter, call you local pool store and schedule a closing. If the pump is running and water is not circulating, most likely the pump lost prime or your filter needs to be backwashed, or there is some debris in the impeller.
Nov 25, 2008 | Hayward H Series Pool & Spa Heater 400k...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
