Question about Kenmore 54351 Dehumidifier
How do I attach a hose to 35 pint kenmore dehumidifier will not run model # 42 54351
I have had it for 2 years. It didn't have a manual and I can't figure out how to attach a hose to drain to my sump. What size hose do I use for this?
SOURCE: Kenmore 54501 Dehumidifier
Clean the hose (it's full of black gunk)
Posted on Aug 12, 2008
SOURCE: Dehumdifier won't drain
You just need to get the water flowing and start the siphoning process by taking out the water bucket while it's full of water and raising it up high enough to start the water flowing. Once the water starts flowing, you can put the bucket back and the water will keep flowing (by capillary action). If the bucket empties completely, you may have to do it again periodically to get the water flowing again.
Posted on May 17, 2009
SOURCE: I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
Posted on Jun 17, 2010
heatman101
  • 43501 Answers
SOURCE: Kenmore 35 Pint Dehumidifier Energy Star 54351 is
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jan 27, 2011
  • 4736 Answers
SOURCE: My 35 pint (42 54351) dehumidifier is only ~2
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit, set
the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
I hope this helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Posted on Aug 15, 2011
Testimonial: "This solved the problem! I took the unit completely apart before realizing where the filter is. I cleaned everything & re-assembled & it's fine. Thx!"
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Soleusair 45 pint dehumidifier won't drain through hose
We have a Soleus Air 30 pint that initially would not drain through the hose that we attached and dropped down the sump drain. After reading here, I tried tilting it back about a quarter inch and that didn't fix the problem. Then I tilted it forward a quarter inch (I put a couple pieces of cardboard under the back wheels) and it started draining properly. It is doing a marvelous job of dehumidifying the house now!
Mar 04, 2012 | Dehumidifiers
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
Sep 11, 2011 | Haier 45-Pint Dehumidifier
Unit will not run and the code 'LO' show up. What does the 'LO' code mean?
Hi, it simply means that the humidity level is lower then 35% the lowest setting on the dehumidifier...
It will not run when showing that...
Jun 09, 2011 | Haier 45-Pint Dehumidifier
The bucket fills with water even though the humidifier is attached to a hose
Most of the units do not require the bucket to be in place, when the hose is attached. However, since you didn't list the Model Number of your unit, I can't be sure that's the case with yours. However, if you click on the following link, and enter the correct model number, you can download and print the Owners Manual for future reference.
http://whirlpool.com/custserv/index.jsp
Hope this helped you to sort it out.
Apr 21, 2011 | Whirlpool 75-Pint Dehumidifier
Kenmore 35 Pint Dehumidifier Energy Star 54351 is really hot to touch and shut off
heatman101
Jul 05, 2010 | Kenmore 54351 Dehumidifier
Jul 09, 2009 | Kenmore Dehumidifiers
Kenmore 54351 Dehumidifier Logo
43 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
