Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Fridge side cold freezer not. compressor seems to be short cycleing
    President:
  • 2,468 Answers
If theres a clicking noise behind the unit,then the ptc overload relay is weak and dropping in and out which will short cycle the compressor, also a compressor thats going bad will draw excessive current and make the ptc drop in and out check start and run currents to determine this,also,but rare it could be the cold temp control
Posted on Feb 23, 2012
  • 115 Answers
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Posted on Dec 30, 2008
deby69
  • 16 Answers
SOURCE: whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Posted on Jan 05, 2009
Sea Breeze
  • 4654 Answers
SOURCE: fridge not staying cold
Inside the fresh food compartment there is a defrost timer hidden behind the temp control panel. Sometimes there is a plastic plug over the hole that you need to put a flathead screwdriver in and slowly turn it clockwise. When compressor stops I want you to wait about 25 minutes to see if the refrigerator comes back on by itself without help. If it does I need you to listen inside the freezer compartment for sa sound of crackling or sizzling noise indicating defrost is taking place. Let me know, Sea Breeze
Posted on May 20, 2009
Greg20
  • 149 Answers
SOURCE: fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Posted on Jun 11, 2009
aborcass
  • 2651 Answers
SOURCE: The strip between freezer and fridge is very hot
sounds as if you either need to clean the coils under the unit,they are clogged and unable to disapate correct amount of heat, or your fan mounted behind the unit, next tothe compressor has failed..YOUR UNIT IS WORKING EXTRA HARD TO GET RID OF HEAT.check those 2 places
Posted on Jun 15, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Oct 27, 2007 | GE GSS20IEM Side by Side Refrigerator
Frigidaire Side by Side Model: PHS68EJSB0 The temperature is warm on both the freezer and fridge. They are at about 25F and 60F. I have cleaned the condenser coils and they are wet now. Initially, the...
If you have the door alarm continuously beeping you will need to try and hard reset the unit. Turn the circuit breaker for 4-5 minutes and retry the unit. But if still the 5 beeps are coming on, then its problem with control panel board.Its not detecting door closed.------- The control board needs to be inspected.---------- If the doors are not getting closed, that means some cold air is getting out and thts why temp is not getting set.This is one possibility of temperature problem.-------- But if both doors are closed tight and no issue of air getting lost out, then other possibility for this problem is weak compressor.-----------
The compressor just keeps on running.The problem is weak compressor.The refrigerant in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Aug 21, 2011 | Frigidaire Professional Series PHS68EJSB...
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
May 01, 2011 | Arctic Air Freezers
Fridge and freezer doesnt seem cold enough. Things are cool but not cold. Ice cream is not as hard as usual (soft but not melted). Ice maker not making ice. Adjusting thermostat doesn't seem to make a...
Please check the timer the thermostat and the heater for the auto defrosting to work. Switch off the fridge and after all the frost has gone off switch on to see if the sooling returns . If so you can be sure that the timerr does not work and so reduces cooling on frosting. If there is still no cooling then you will need to check onthe compressor and the gas pressure. Get help to confirm and take an estimate before attempting, get an warranty assurance for work. Hope you try out and see first.Good day
Aug 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
371 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
