Question about Sony DVP-SR500H DVD Player
Sony DVP-SR500H frequency change
Component video output frequency is off. Color is gone, appears as beat frequencies on b&w image. Vert freq off far enough that older tv won't lock on it. Different cables, different tvs, problem stays the same. Working fine until problem showed up. Problem has stayed the same; not an interment. 7 months old so 90 day warrenty is up. Anything I can do? Is there a history on this kind of thing for this unit that could help?
  • 4 Answers
SOURCE: picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Posted on May 07, 2008
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Posted on Apr 01, 2010
Demonic-2011
  • 508 Answers
SOURCE: Hi, I have a sony DVP-SR500H dvd player. I've had
T-LCK indicates device protection, not child lock - you will need to take it to an authorised Sony service centre; they will charge a quote fee to tell you what parts if any need replacing and what's involved (always ask for details) - you can then make a decision on whether or not to go ahead with the repair.
Maybe there is a modification the service centre can carry out to permanently disable this unnecessary protection; it isn't reliable. As I say, you can always say no to the repair after the initial quote if you feel it is going to cost more than the machine is worth.
Posted on Feb 12, 2011
shajanrs
  • 890 Answers
SOURCE: i just bought a
It is required to use the Eject button on the DVD player to eject the disc tray. It is not a dump question. Unfortunately, it is a bad design. However, it is required to go near to the DVD player to change/insert the disc. Hence, the eject button is not available on the Remote.
Thanks for understanding.
Please let me know if you require any further assistance.
Posted on Apr 13, 2011
SOURCE: Region unlock a Sony DVP-SR500H
Ok here's what I've figured out for Sony dvp sr500h...
To get to the hidden menu, you need to start with the DVD player power OFF
then hit
TOP MENU
CLEAR
POWER (to turn the dvd player on)
and you should now see the hidden menu
then go to option 2
then option 4
then this is as far as I get...you can enter codes here but none I've tried have worked....
the ones I've tried so far are 2812, 34570, and 12450
if anyone can figure out the correct code please post here.
Posted on Jul 23, 2011
Formats for dvp-ns70h
selectable 720p/1080i output via HDMI digital interface (separate adapter available for TVs with DVI input)
selectable progressive-scan mode for smoother video with HD-compatible TVs (via the component video output)
optical and coaxial digital outputs for Dolby Digital/DTS /PCM
  • 1 set of audio/video outputs (composite, S-video, 480i/480p component video, and HDMI)
  • plays DVD-Video discs, DVD-Rs & DVD-RWs, and DVD+Rs & DVD+RWs
  • plays CDs, CD-Rs & CD-RWs, and MP3 CDs
  • plays digital picture CDs (JPEG)
  • remote control (multibrand for TVs)
  • 108MHz/12-bit video DAC
  • 192kHz/24-bit audio DAC
Oct 14, 2012 | Sony DVP-NS70H DVD Player
Sony dvp-sr500h will not spin and reads error
The error likely is the unit detects the platter is not moving---unless an expensive unit it will be cheaper to replace the player than fix it.
Jun 13, 2012 | Sony DVP-SR500H DVD Player
We bought a new Sony DVP-SR500H dvd player. I hooked it up with hdmi cable. It will not eject the tray to load a dvd. It just says "load" - no errors. Not childproof locked. Help!
After NOTHING worked (including tips from other sites) I took it apart and literally forced the tray in and out of the player. Guess what? The damn thing works like a champ now!!!!!
Feb 06, 2011 | Sony DVP-SR500H DVD Player
Scanner not picking up local police-Fire freq
Do you still receive NOAA weather frequencies? Sounds like your local agencies have switched from simplex/standard frequency operation to trunking. I suggest you visit www.RadioReference.com to view the latest on active frequencies and systems in your area.
Bill B
May 17, 2010 | Radio Shack Pro-94 Scanner
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Deleting frequcies
Clear out everything do the following
While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAr appears.
To take out individual Freq. Manually tune to that freq. Ch/Bank on the scanner. Enter 0.00 like a new freq for that ch. and it will be gone.
Jun 22, 2009 | Uniden BC72XLT Handheld Scanner
How do you audio output to a stereo amp
if your amp has a optic cable slot u may need one of these to transmit sound from ps3 to amp :)
May 17, 2009 | Sony Playstation 3 (PS3) Console
Dvd in black and white should be color
Your probably had connected with a component video without changing the video setting!If you video setting is under composite/S-Video output but you end up connect the video source with component video cable,you need to go to the setup to change it.
It could be the other way around too!
solutiondoct
Nov 01, 2008 | Sony DVP-NS315 DVD Player
Sony DVP-SR500H DVD Player Logo
113 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
