Question about IBM ThinkPad T41 Notebook
No power to my t41 ibm laptop
Hello, I have no power supply to my T41 IBM think-pad laptop. Both charger and battery have been tested and are OK. I have noticed a loose wire to the rear, which looks as though it should connect to a daughter card. But I haven't one!!! Weird.... Would this be the cause of the lose of power? If yes then what has happen to the daughter card as my laptop has always worked up until this problem a few days ago.
  • 4 Answers
  • 1019 Answers
SOURCE: IBM T41 WILL NOT STARTS UP SOMETIMESTHEN WHEN IT DOES IT FREEZES
problems will be with:-
1:- installed memory ( not enough or damaged memory module ) RAM
2:- The Processor ( CPU ) Is Overheating.
3:- Hard-Drive. The unit may have bad or defective sectors.
4:- Computer Virus Or Similar.
Solution:- remove 1 memory module from the computer ( located on the underside computer ) boot the computer. see if this helps. try changing memory between the 2 allocated slots.
Check the CPU Fan, is not clocked with dust/debris. ( Can be accessed by removing 2 screws on the underside or the laptop ) Marked with >> or similar. remove the fan, 3 small screws and brush with a soft dry paint brush or similar, remove any dust from fan and check for blockages.
run a scandisk or hard-drive checking program, to test hard-disk unit et,c.
following these steps, should solve your problems.
Mike @ Compurepair. " Thankyou For Using Fixya "
Posted on Nov 22, 2008
SOURCE: ibm t41 sound not working
Just to try the obvious...
The volume buttons on the laptop underneath the screen work independently to the volume controls in Windows. Have you tried pressing and holding the volume up button and then playing a sound?
Posted on Jan 21, 2009
leecom72
  • 4806 Answers
SOURCE: recovery cds for ibm thinkpad t41 laptop
Hi there.
Unfortunately you cannot download the recovery CD for free, you can download them but it is going to cost you.
Take a look at this site for all IBM Thinkpad recovery CD's >>>>
http://www.thinkpadrecoverycds.com/
Good luck and thanks for using FixYa!!
Posted on May 26, 2009
  • 105 Answers
SOURCE: IBM thinkpad T41 -> get
The IBM Thinkpad has a very strong security system.
If you are seeing a lock symbol when booting then somebody has set the supervisor password. If you can't remember it or guess it (try "password", "admin", "pass", etc) then you need to find the person that set the supervisor password.
Once the supervisor password is set the T41 is very well protected and it can't be reset by removing the laptop battery or CMOS battery.
There is a way to read the password from the protection chip but this is very complicated and requires taking the laptop apart and building your own chip reader.
The instructions for doing this are are:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Hope this helps,
Chris
Posted on Mar 08, 2011
hulk917
  • 247 Answers
SOURCE: I need drivers for my
Here is a link that will give you all the drivers for your T41...... It covers xp vista and Windows 7 Good luck and take care :) http://www-307.ibm.com/pc/support/site.wss/product.do?doccategoryind=50370&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&brandind=10&familyind=154110&machineind=154114&modelind=0&partnumberind=0&subcategoryind=0&operatingsystemind=49979&validate=true
Posted on May 22, 2011
I need drivers for my ibm think pad t41 2373 leptop
Software and Drivers for your notebook canbe found HERE.
Good Luck, KoBaC
May 22, 2011 | IBM ThinkPad T41 Notebook
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
I am using IBM t41 think pad, but from last 2year ...
There might be loose parts or connection inside the laptop. Is your laptop still under warranty. If it is still under warranty, i suggest that you have it repaired at our depot repair department. Opening the laptop on your own will void the warranty.
May 21, 2010 | Lenovo ThinkPad T41 Notebook
Thinkpad T41 switching from battery and charger
if the laptop is switching between the charger and battery on its own, then that means you have a loose AC Jack on the back of your laptop, it would need to be either resoldered so its not loose anymore or the jack would need to be replaced.
Jan 24, 2010 | IBM ThinkPad T41 Notebook
T41 appears to be dead. I see the power light but
Good day sir, there are several resons why a laptop wont power up, or wont display a thing.
  1. Memory is bad so make sure to check for memory module.
  2. The battery is bad, check you battery with other similar laptop.
  3. The power supply/charger is bad.
  4. There seem to be a shorted circuit board on your laptop ground chassis. For you to test it, you should dissassemble the laptop and one by one reassemble it again.
  5. Mainboard, sad to say if everything else fails, the mainboard is the last culprit. better visit your local service center.
hope this helps, please update me if you may have any progress report on your laptop, thanks
Jul 24, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Recovery cds for ibm thinkpad t41 laptop
Hi there.
May 26, 2009 | IBM ThinkPad T41 Notebook
IBM ThinkPad T41 (9 Cell Battery)
It can over charge it.
it happens alot with laptops.
Feb 04, 2009 | IBM ThinkPad T41 Notebook
Power shut down after inserting usb driver or usb mouth
This failure is caused by the usb drivers conflicts, power supply or failure on the motherboard - You can go to the IBM website and check it out more about this issue.
Sep 24, 2008 | IBM ThinkPad T41 Notebook
IBM T41 No power
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Installing a pc computer power supply
Once no power supply is installed into the computer, place the new power supply into the computer and screw the screws into the back of the power supply.
POST troubleshooting steps. Note: Make sure your computer is turning on, if you press the power button and nothing happens (no lights, no sound, no fans, etc.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | IBM ThinkPad T41 Notebook
IBM ThinkPad T41 Notebook Logo
221 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
