Question about Husqvarna Hand Held Blower 125 B Grass Leaf Blower ()
Whats the best premix gas to use on a Husquarna 125B hand held Blower
Whats the best premix gas the 40:1 or the 50:1
  • Husqvarna Master
  • 885 Answers
The best mix to use is what's recommended in the manual but in most cases blowers use a 50:1 mix. The difference from 40:1 to 50:1 is negligible but you have to use what the motor is built for. Too much oil causes a loss of power because the gas won't burn efficiently. Too little oil and you risk damaging your piston or cylinder.
Posted on Feb 23, 2012
2 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Posted on Aug 02, 2011
What screw is L & H on husqvarna leaf blower 125b ?
unit is running lean. The lo is closest to the crankcase. Give the lo a half turn out.
Aug 31, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
Jul 26, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
New Husqvarna 125B blower runs fine then stalls
Is the gas fresh or old that you used. Since this brand new, it's under warranty. If you've had it for a few days, return to the store from which purchased it. It should run right out of the box without having to work on it.
May 16, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Starts fine, run fine,for about 2 to 5 min.,then cuts off,sounds like it's not getting the gas.
I have a Husqvarna 125B same problem. Turned out to be a bad gas cap. Doesn't vent properly and starves the engine. I took the gas cap off of my Huqvarna weed eater and put on blower and blower worked fine,
Nov 11, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
How do I get the spring back in my Huaqvarna 125b blower?
you have to wind the spring back in, one coil at a time , its not too easy i would say the best thing is to order a new spring, this will come in a keeper so makes fitting easy.
May 26, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Husqvarna Hand held blower. Model # 125-B No Spark
husqvarna model 125b weed trimmer what spark plug do i use manual says rcj-6y in technical data and rcj-8y in monthly maint. ????
Jul 21, 2011 | Husqvarna 125bvx Hand Held Blower Vac
Husqvarna Hand Held Blower 125 B Grass Leaf Blower () Logo
219 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
