Question about HP Photosmart R937 Digital Camera
How do I find the hp r937 software - HP Photosmart R937 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Posted on Feb 23, 2012
How do i fix a Hp Hewlett Packard photosmart r937 digital camera?
Not sure on the camera model but cameras usually don't take 12v so I would comparability of charge voltage would be the problem. Cameras take 3v to 6v usually. Check the specs of your camera that will tell you what it needs. Hope this helps.
Feb 23, 2015 | HP Hewlett Packard Photosmart R937 Digital...
HP PHOTOSMART R937
If you have only had it for 6 months, I would recommend sending it in to HP to be serviced.
Thanks,
Lee
Jul 21, 2008 | HP Cameras
Wrong colors on screen
There is a problem that needs to be looked at by camera tech.
Jan 17, 2013 | HP Photosmart R937 Digital Camera
How do i change my iso setting
Your camera is capable of ISO adjustments from 100 to 1600. Photos taken at ISO 100 require the longest exposures and will have the best quality color and least amount of graininess. This setting should be used as often as possible and is ideal for well lit subjects. Conversely, ISO 1600 is for low light situations. Photos taken with the camera set to this value will have muddied colors and much more graininess in them. This is often preferred to having no photo at all.
The down side to this camera - like most point & shoot ("P&S") types, is the fact the the light sensor that actually captures the image from the lens, is quite small. Small sensors have difficulty rendering acceptable photos when taken at high ISO settings. It is not unusual for P&S cameras to perform unacceptably at ISO 400 and up. Reviews I have seen on your camera back this up. Basically, ISO 100 and 200 are the only values that provide acceptable photos. You should experiment with the entire range of ISO under different lighting conditions to see which situations and ISOs are acceptable to you.
Your camera makes use of icons to access menus and they do not show up well on FixYa, so I will need direct you to an online manual that you can view or download. It can be found here.
Chapter 3 (begins on Page 16) talks about camera menu settings. Your should review this chapter, and pay particular attention to "ISO" on page 20. You will learn how to select ISO 100, 200, 400, 800 & 1600 on the camera.
I hope this helps & good luck!
Sep 27, 2012 | HP Photosmart R937 Digital Camera
My touch screen is not working correctly can it be repaired
in settings menu you will find a test to set the touch screen. Every device with touch screen have this test. After you will run this test, every thing goes back to normal. This test it should look like a white screen with small cross. You should push in the center of that cross.
May 31, 2010 | HP Photosmart R937 Digital Camera
Hello i have the hp r937 and i had dropped it and the door to the battery will not close now i think a part on the actual camera broke of not on the door is there a way to fix this?
Did you find someone that fix it?. I dropped mine today and there was a small plastic piece that helps to close the door, it broke, now the door won't close.
Nov 22, 2009 | HP Photosmart R937 Digital Camera
Our Sharp R937 Microwave is playing up. It is
oh dear, its just about to pack up on you, the power supply is on its last legs,, my addvice is dump it and buy a new one, fixing it will cost you both arm's
dont go trying to fix it yourself,, if you go inside of this unit and tuch the wrong bit it could very well kill you stone dead, there may well still be over 1000' volts flying about inside of it,,, volts kill you!!!!!
play it safe,, buy a new one!
Oct 21, 2009 | Microwave Ovens
I lost all my pictures. do not know why .my memory stick is still
i suppose if you have connected your camera to a system which is either virus affected or you might have deleted them accidentally. but dont worry you can retrieve the deleted photos from your memory card, for which there are softwares. you can google search for them and install them in your system.www.p-dd.mobi/ ....... the above said website contains the softwares. it is an example.
Aug 15, 2009 | HP Photosmart R937 Digital Camera
HP Photosmart R937 Digital Camera Logo
49 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
