Question about LG 50PT350 50 in. Plasma TV
Power clicks on then shuts off - LG 50PT350 50 in. Plasma TV
  • Rajesh Feb 23, 2012
    Thanks a lot Chester! but i should have added a little more details, actually what happens is the tv turns on then after like 3 to 4 seconds i can hear it click off.
    There is not enough time for the screen to light up.
    I have a power supply board coming in the mail, hope it solves the problem.
    I really appreciate your response, if you have any other suggestions I would to hear from you or anyone else who experienced this problem, thanks again!
  • Rajesh Feb 25, 2012
    Still awaiting the power supply board its in the mail
    Sergeant:
  • 195 Answers
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Posted on Feb 23, 2012
How do i shut my acer chromebook down after use please
Power off your Chromebook To turn off your Chromebook completely:
  • From your desktop, click your account photo, then click Power .
  • Click your account photo, click Sign out, then click Shut down.
  • Press and hold the Power key for three seconds.
Jun 09, 2017 | Acer Computers & Internet
Tip
Change the Sleep Button on the Start Menu to Shut Down
Want to shut down Vista with one click, instead of sleep.
Open Power Options in Control Panel
On the current plan your computer is running, click change plan settings
It will open Edit Plan Settings, find Change Advanced Power Settings and click on it.
Power Options will open, find the expandable tab that says Power Buttons and Lid, expand it.
Expand the tab that says Start Menu Power Button.
If you are running a laptop there will be two options, one for On Battery and one for Plugged in, click on the word sleep to open a pull down menu.
Click on the arrow, than Shut Down.
Click Apply and than okay. Close all Windows, Shut Down should be on the start menu instead of sleep
on Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
How do I turn off windows 8
To turn Off your Windows 8 PC, you can click the Power button on your screen and then click "Shut Down". If there is no Power button on your screen, you can follow the instructions below:
1. Swipe in from the right edge of the screen, and then tap "Settings".
(If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click "Settings".)
2. Now, click or tap Power and then, click or tap "Shut Down".
The following link can be useful:
http://windows.microsoft.com/en-IN/windows-8/how-shut-down-turn-off-pc
Hope this will help you.
GuruAid.com
Sep 27, 2014 | Dell Computers & Internet
How do i turn off windows 8
1. In Windows 8.1, from the Start screen, click the Power button and select Shut down.
If you can't see Start screen, point the mouse to the bottom-right corner of the screen, click Settings, then click Power, then click Shut down.
2. From the Start button, select Shut down or sign out and then Shut down.
Jul 08, 2014 | Computers & Internet
Turn off windows 8
Hp P6653 won't shut down properly after clicking shutdown
Open Control Panel, select Power Options, select High Performance, Use this procedure to set the Advanced power settings: http://www.makeuseof.com/tag/windows-7-power-options-sleep-modes-explained/ Use these tip to speedup starts and shut downs: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 Try Freeware MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL scan, delete ALL results, reboot.
Mar 09, 2013 | HEWLETT-PACKARD Pavilion p6653w...
When I shut down the computer, power is still opperating USB ports and front button light illuminated,.
In that case you aren't actually shutting it down, you are putting it in sleep mode.
In Start > Turn Off Computer window make sure you always click on the Turn Off button but if you're in Vista or 7 pressing Start > Power sends the pc to Sleep by default. To change that to normal behaviour - the Stop button actually stops the pc - follow this:
1 - Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Power Options.
2 - Under the currently selected power plan, click Change plan settings.
3 - In the Edit Plan Settings dialog box, click Change advanced power settings.
4 - In the Power Options dialog box, click the plus sign (+) next to Power buttons and lid to expand the list.
6 - Click the plus sign (+) next to Start menu power button to expand the list; in the Setting list select Shutdown for the Power button. Click OK.
Jun 18, 2010 | E-Machines eMachines Desktop PC
Toshiba satellite P15-S420 odd power & freezing problems
  1. Click Start and then Control Panel.
  2. If you're in Category view, click Performance and Maintenance.
  3. Then click on Power Options.
    If you're in Classic view, double-click on Power Options.
  4. Click the Hibernate tab.
  5. The Enable Hibernation box should be unchecked.
  6. Click Apply.
  7. Click the Power Schemes tab.
  8. In the Plugged in column, from System Standby option, set a time out period.
  9. Click Apply.
  10. You can adjust the Turn off monitor and Turn off hard disks settings as well.
  11. Click Apply. Click OK. Close the control panel.
This is what you should see
Please rate this a fixya
Feb 09, 2009 | Toshiba Satellite P15-S420 Notebook
Hp pavilion s3015 goes to sleep at startup and does not recover
Shut down the PC by manually powering it off by holding the power button in until it is off. Start the PC. Does it boot correctly? If so, turn off all the Vista power modes.
Click on Start and in the "Start Search" block type "Power". Click on "Power Options" which should show up above the Start Search area. Put the dot in "High Performance" then click on Change Plan Settings, Change Advanced Power Settings, Click on Power Buttons and Lid, Start Menu Power Button, Click on "sleep" to reveal the other settings - select "Shut Down", then "Apply" then "OK". Close all open windows and shut down the PC using the Start button. Note the power button icon is now RED not amber as before.
Run the PC in this mode and see if the same problem occurs. If so, you have a different problem.
Apex44
Jan 07, 2009 | Computers & Internet
Computer won't power off
The most common reason for this problem is that ACPI (the Advanced Configuration and Power
Interface) isn't enabled. To enable it:
Click Start | Control Panel, select Performance and Maintenance.
Click the Power Options tab.
Select APM - Enable Advanced Power Management Support.
Click OK.
Dec 29, 2008 | ASUS P5ND2-SLI (890552603831) Motherboard
LG 50PT350 50 in. Plasma TV Logo
185 people viewed this question
Computer Repairing
Computer Repairing
