2008 nissan altima cd player says reading error wont play disc
Benimur
  • 6966 Answers
SOURCE: CD Player problem
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded;
5. relube, clean as necessary
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 11, 2008
smarthome2
  • 1114 Answers
SOURCE: Sony CDP-C225 will not read or play cd's
Try running a "Laser Lens Cleaner" thru it, preferrably one that uses fluid. You can purchase one at just about any retail store for 15-20. Good to have and great preventative maintanance. If that does not work, you need a new transport, they do not repair or align lasers. Too expensive. The replacement is 100-150 with labor and a new one is under 200. My suggestion would be if the cleaner does not work replace it and keep the new one clean. CD/DVD/PC etc. all can and should be cleaned 3 or 4 times a year. Best preventative maintanance you can do. Hope this helps
Posted on Jun 24, 2009
  • 6 Answers
SOURCE: cd player not reading discs.
The reader is not recognizing the disc which usually means there is a problem with the circuitry or the "eye" itself. It will probably cost you more to repair this unit then to purchase a new one. Especially since CD players have come way down in price.
Posted on Oct 27, 2009
SOURCE: Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Posted on Nov 03, 2009
  • 21 Answers
SOURCE: Emerson 3 Compact Disc Player
Hi
If the machine cant read the table of contents of a disc this would suggest either the lens of the optical pick up is dirty or the optical pick up has failed completely or something directly relating to the optical pick up i.e the spindle or stepper motor, if you can easily acess the optical lens you maybe able to clean it using a cotton bud and re-test, just try this with a dry contton bud to begin with if this gives an improvement you may wish to use a cotton bud with a alchol cleaner like I.P.A,
make light circular movements over the lens. If this makes no difference the machine requires repairing, so consult a local service engineer.
regards
TechSupp12
Posted on Dec 11, 2010
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Altima cd player
try cleaning it with one of the dvd cleaners may have dirty heads
Mar 24, 2014 | 2012 Nissan Altima 2.5 S Coupe 2.5L 4-cyl....
Cd player in my 2007 nissan altima 3.5sl loads, but will not play
check the format needed by the cd unit to read the cd's.
Jan 04, 2014 | Cars & Trucks
CD player doesn't read and it displays disc/focus error check disc
most common cause is a dirty or bad optical pickup in the unit, it may be able to be cleaned but more common is the pickup is bad.
Dec 18, 2012 | 2007 Nissan Altima
CD player reads disc/focus error check disc
Optical pickup inside which reads the disc is likely dirty or bad.
The radio plays, but when i go to try nd play the cd player error1 keeps coming up.what exactly is error 1.&& do you think i need a new deck?
It can't read disc, try another disc preferably factory bought recorded disc not computer MP3 version off computer
Feb 24, 2011 | 2003 Nissan Altima
I have a 2007 Altima and when I insert a DVD-R disc that has mp3 and wma files I get a read/focus error. If I put a insert a regular cd with audio files they play fine. What would cause this error and is...
There is a major difference between the way a DVD is formatted and used and the way a CD is formatted and used. For that matter there is a major difference in the way these are manufactured. There is nothing wrong with your CD player. Try burning your disk to CD-R media and make sure you close the sessions instead of DVD-r media.
Oct 03, 2010 | 2008 Nissan Altima
It doesnt read any cd
optics are/have failed
you will need to replace the CD player
Apr 12, 2010 | 2003 Nissan Altima
I have a read/focus error on my CD player. The radio works fine but the CD doesn't work.
The laser light is out of focus and that is why it will not play cd's you might have to replace are take to the dealer to fix that problem they have the proper tools
Mar 06, 2010 | 2008 Nissan Altima
1,290 people viewed this question
 Grubhead
Grubhead
