Question about Intel Motherboard
Xp pro only booting to desktop with no short cuts or even start icon
Had to upgrade to a new mother board , processor and ram kept old hard drive which was working fine.Did a repair and install. System now boots to desktop but only with background picture and nothing else.Did repair and install from original xp pro disk(no services packs) how do I get past this point to reinstall the service packs etc
  • backa1 Oct 29, 2008
    SP disks are not bootable.Have already scanned for virus and adaware with nothing found
  • backa1 Nov 13, 2008
    Sorry for taking so long to get back. Ended up reinstalling a clean xp and its working. still have to load all my other programs but at least most of my data is safe(3 partitions on the drive) Have scanned for virus and addware but all come back clean.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
I wouldn't know if this would help, but here it goes. Before the motherboard was replaced, you should have gone to Device Manager and uninstalled the devices related to that motherboard like the chipset and other onboard devices that came w/ the motherboard. If you want to clean it up, you can still do this: start>run>type: cmd and command prompt should pop up. In prompt, type: set devmgr_show_nonpresent_devices=1 then enter. Then, type this: "devmgmt.msc" w/o the quotes. Device manager should pop up. Go to the view tab and select "show hidden devices" and maximize the window. What you're going to do is uninstall any device(s) you know you don't have, or don't exist anymore. These devices show a faded icon representing the device, so what you do is go down the tree by clicking the + sign and uninstall the devices w/ the faded icons. Go through the whole thing, and keep in mind not to uninstall anything that says Microsoft on it. And if you're not sure, don't uninstall it. But i believe that most of the ones you see faded wil most likely be uninstalled. I wouldn't know about the part when you tried to repair it w/ th xp cd, but if by any chance you ever end up replacing the motherboard and keeping the HDD, before you change it and turn it off, make sure you uninstall the chipset drivers along w/ all related to that part before you put in the new one. Because when you woke it back up, the configuration were still registered on the HDD as the old one. Sowhen it loaded the neccesay drivers for the hardware, it had a conflict because of what registered versus what it detects. Hope you fix it.
Posted on Nov 13, 2008
    Novelist:
    Scholar:
  • 141 Answers
Have you tried to boot from the sp disk? I don't really know if it has an executable file. You may have a hard drive virus. Try doing a repair of your os first, download free avg 8.0 and free adaware se. Run avg first.
Posted on Oct 27, 2008
  • Theresa  Smith
    Theresa Smith Oct 30, 2008
    What doesn't make sense is that you say you did a "repair and install" ! It's kinda either - or. Why did you do both and in what order?
    Your system boots to a point/ loads the os and you have an xp desktop right? So it's like the os was installed; just isn't booting completely. Then comes the customizing of your personal settings. You have a desktop but from what you said you also used the same hdd since it worked fine. There are all kind of virus/ trojans. Installers/ downloaders/ executable, which may be on your old drive. Why don't your try the recovery option, you know the recovery not repair option; the one before hitting F8/ R. When you get the prompt type: "FIXMBR" (master boot record). Then follow prompts choosing 'Yes" you are sure. After confirmation that new MBR has been written, at the next prompt type: "FIXBOOT", follow prompts. Restart. Let me know what happens at that point. You may have to do another repair which is the option after hitting F8 /R.
    Good Luck.....
Computer don't start,
If it doesn't start at all, check motherboard for a short by unplugging the processor power cable (4 pin normally), and turn the computer on. If the fans start rotating, it is probably a short. If that isn't the problem, check for cables that should be connected, and test the processor in another computer. Hope it works (it did for me)
May 27, 2014 | Powerspec G213 Desktop Computer; Intel...
Mother board is ak77 pro 133 vt8233 will not run xp proI
The BSOD (blue screen of death) usually means that a computer component has failed. This could be a hard disc drive, a memory module, the cpu, or the motherboard. I would start by checking out the hard drive first. See if it is spinning and not making any clicking sounds. Try replacing it if you have another one. Then check memory and cpu. Some people actually like having an old computer hanging around. They install Windows 98 in it so they can play old dos games and games that don't require a blazing fast processor! Good luck...Hank
Jan 09, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Is it easy to upgrade my own emachine so it will be faster and have a larger drive?
1st open the pc case and write the motherboard model.
then go to the motherboard company website, and check for the latest firware for your board, then check for spec for your board, memory, an so on... (Note the windows xp has limited hd size. and choose a 10000rpm hd disk and 16M buffer with a top graphic card for your board, and update the cpu), and your computer is tunned.
Dec 29, 2009 | Computers & Internet
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Will motherboard will support winXP pro
Hi gimondor,
The motherboard really isn't your worry. Windows XP pro requires a 300 megahertz or higher processor. You motherboard can take from 100 to 400 megahertz, so you need to know what your CPU is. If your running an intel P4 chip, and at least 128 mbs of ram, and you have at least 2 gb's of hard drive space left on your hard drive, then you can run XP Pro.
Good Luck,
And please leave a rating based on my solution.
Mark
Apr 06, 2009 | AOpen AX4BS Pro (91.89J10.001) Motherboard
Windows XP won't boot with "CREATIVE SOLUTIONS" PC
That machine is too underpowared to run xp pro.
Windows XP Media Center Edition
1.6 GHz CPU, 256MB Ram, and DirectX 9 hardware-accelerated GPU
you may get it to run but it is going to be dead slow. you will be waiting forever to load any apps with a processor under a gig, and less than 512 mhz of memory, it may work for emulation, but that's even questionable. I don't want to aggrvate you but that config is a decade old. Vista for instance needs at least 2 gigs of ram and a dualcore to run right. sorry bud, if you are dead set on it, the only thing you coula do is juice up the memory, to whatever the board is rated to take, or I would run windows 98, peace
Feb 03, 2009 | Dell XPS™ 600 PC Desktop
I want to upgrade my system from KM266-8235, 1.53 GH processor
Hi, you can do what i always recommend to my customers, install a new industry standard architecture (ISA) motherboard kit which will include a motherboard, processor,memory bundle. This future proofs you pc for at least five years, enables you to upgrade memory and processors on a plug 'n' play basis. fitting a kit is dead easy, with full instructions and what's more you will not lose any data on your hard drive either. More info ?
compdoctor2005@btinternet.com
Dec 11, 2008 | HP Computers & Internet
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Quantum fireball 10.2gb
The computer speed completely depends on the speed of quantity of RAM, HDD, processor and FSB of mother board. Your processor is good enough to give better result with windows XP and did not mention about the availability RAM, if less than 256 MB, you need to upgrade and you can upgrade HDD not so mandatory if you have more than 20% free space. Under maintenance practice do regular "DEFRAGMENTATION and CHECK DISK" from selecting driver properties under tool tab.RAM will surely give boost and do degramenation
Apr 16, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Intel Motherboard Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
