Question about Nokia 1600 Cellular Phone
Turn cell off at night -am party calls "why caal mw 532am phone was off no one on my line?
P hone off at hight. in a.m. Caller calls meask me why ring him 530 A.M.M y phone? Same thing dont know why phone on again light on nombers, letter light on . N o reason phones still on and phone still connected to battery? please explain? dont want time running on my phone Howard dabney is it shutting off??? the keypads of my nokia 1600 cellular phone are not working
  • rose82 Jan 30, 2009
    my keypad seems to be frozen - nothing going on when they are pressed. phone is on and lit up.
Led light not working
Posted on Dec 25, 2008
If i want to reject some call. thn how could it b possible
Without a specific make and model from you, I dont know about your phone specifically, but most cellphones,if you press the End Call button while the phone is ringing, it will reject the call.
Most cellphones send the caller to voicemail when the call is rejected. Some simply cut the caller off.
I am almost certain that this will work, I have yet to see a cellphone that doesn't.
Make sure you have Any Key Answer turned OFF in your Call Menu...
Some phones let you choose which activity answers incoming calls. Most options are Answer Key to answer, Any Key To answer, or Flip Open to answer. Choose the Answer key Only to pick up calls.
Then, when you press the End Call button, your caller will be rejected....
Good Luck!!
Feb 01, 2011 | Cell Phones
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
One of our office phones is set up for voice mail yet the phone rings continuously. It won't offer the caller voice mail. Any suggestions?
You need to go into system programming and set that extension to "Forward no answer" to the extension of the voicemail.
If you dont know what that means, I would call someone in, as you can ruin your system by doing the wrong things.
Aug 05, 2009 | Nortel Lands Phones
Turn off caller id
Unfortunatly the only way to do it is to take line access off that phone and have a button call pickup to access ringing line. In this scenario extension wont ring Reffer to programming manual on support/avaya.com Cheers
Jun 10, 2009 | Avaya Corded Phone avaparp18d
LG KU990 Caller ID
  • If you answer the call, the number (or number and name) stays on the display until either you or the caller hangs up.
  • If you do not answer the call, most display units keep a record of the calls received, including the phone number (or number and name), date, and time.
  • If the letter P, priv, private, or a similar term appears, the caller may have blocked the display of his or her number.
  • If the letter O, ????, out of area, or a similar message appears, the caller either is in an area that does not support Caller ID or has placed the call using operator assistance.
  • Caller ID comes with Anonymous Call Rejection, which, when active, allows you to reject calls from callers who block their number. Your phone does not ring, and the caller hears a message saying blocked calls will not go through.
    • To turn on Anonymous Call Rejection, press
      *77 on a touch-tone phone (or dial 1177 on a rotary phone)
    • To turn off this service, press
      *87 on a touch-tone phone (or dial 1187 on a rotary phone)
or go through
http://www.decommunications.com/support/topics/repairs/phone/no-id-name.php
Oct 13, 2008 | LG KU990 Viewty
Wont accept incoming calls
this happened to mine , I never had aproblem before than one day ??? didnt work . I changed phone jacks ?? dont know why ??
1. Try disconnecting all phones in the household except the phone being affected.
2. Do a test call to see if the unit rings.
3. If the phone rings at this time, begin reconnecting all the other units one at a time. If the affected phone does not ring again, this is an indication that there are too many phones in the loop.
4. If possible try testing the phone on a totally different phone jack (friends or neighbors) to check if the same thing happens.
Also make sure the phone is not connected through an external answering machine, caller ID box, fax machine, computer, splitter, or defective DSL filter. If so then connect the telephone cord directly to the telephone jack and make a test call.
Jun 30, 2008 | Uniden Cordless Phone
Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
Mar 12, 2008 | Panasonic (KX-TG1032S) Phone
Phone does not ring or show caller ID
From extension 10 or 11.
Press feature 00
Press left intercom twice
Then right intercom once.
enter your extension number
You will see the lights blinking green on the phone, where your lines are. Touch them until they are solid green. If you want to program another extension, press the right intercom button again and enter the new extension number.
Once done, press feature 00 to exit programming.
As far as the caller ID, there is no way to turn it off on the Partner system. My guess is the provider isn't sending caller ID.
Jan 04, 2008 | Lucent PARTNER18 Corded Phone
Touch-panel/caller ID speaker phone
My phone did the same thing. It was the spy prevevtion function. pressing (#) for over 2 seconds. turned "SPI OFF". worked OK.
Dec 31, 2007 | Innovage 69420210126 Phone
Nokia 1600 Cellular Phone Logo
44 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
