Question about Vehicle Parts & Accessories
Prestige aps2k4ms remote program - Vehicle Parts & Accessories
  • Vehicle Part... Master
  • 17,970 Answers
I suggest visit this link HERE in order to check program procedure.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Posted on Feb 23, 2012
2 Suggested Answers
SOURCE: Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Posted on Oct 22, 2008
Code alarm protx6 fob programing
I would either go to the website for the manufacturer of the keyfob and search the troubleshooting section or get the company phone number and call them and get instructions for the programming codes. good luck.
Apr 16, 2014 | Audiovox Prestige Code Alarm Remote Alarm...
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
Hi there:
Thank you for using FixYa, have a nice day.
Feb 22, 2012 | Toyota Camry Cars & Trucks
Hi there:
Feb 22, 2012 | 2004 Toyota Camry
HAVE A PRESTIGE APS686T REMOTE START ON A2003 FORD FOCUS.HAD 2 NEW KEYS PROGRAMMED. THE REMOTE START FLASHES MY THEFT LIGHT AND WILL NOT START. HOW DO I PROGRAMM THE PRESTIGE TO MY KEYS.
When you had the new keys programmed, the bypass was erased. More than likely, it was a key. Try this: put the first of the two new keys into the ignition, turn the ignition on. The theft light will light up, then go off. Immediately remove the key and put the second key into the ignition. Turn the ignition on, the theft light will come. When the theft goes out remote start the vehicle with the remote, quickly remove the key from the ignition. If the vehicle starts let it run for a few seconds and then shut the remote starter down with the brake. Wait a few seconds before testing the system.
If the above programming does not work the first time, try it again. It may take a few attempts because the process is time sensitive. You CANNOT allow too much time to pass between switching the keys.
Jun 01, 2011 | Prestige APS686T Remote Start and Keyless...
I have a Prestige APS-20B 3 Button Vehicle Alarm System installed in January 2005 in my 2005 Toyota Rav4 Plus. The Dealer was High River Toyota In High River Alberta Canada. both of my key chain...
You can purchase these remotes online and program them yourself. If you have difficulty programming the remotes come back to FIXYA for instructions. The remotes also should have a phone number on the back for ordering.
May 05, 2011 | APS20B Prestige Keyless Remote Alarm
Have a prestige remote start that was installed and only worked for one week. now the remote beeps but doesn't start or lock/unlock any doors. remote says inhibited . all doors are closed as is hood and...
If this is the Prestige 997C, there is a remote starter disable feature that can be activated through the programming switch. When it is active it will display "inhibit' on the screen. To deactivate this feature, press and hold programming switch, turn key on, off, on, off, on then off. When the hood pin switch is not making contact with the hood when closed, the screen will display inhibit. When the brake shutdown wire is active the screen will display inhibit.
Feb 27, 2011 | Prestige Remote Start
How do i program the remote start function on prestige 997
email me i cant help you,i need to know the model of the alarm and what kind of vehicle is installed here is my email reynosaelectronics@live.com.mx
Mar 13, 2009 | Prestige Remote Start
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Vehicle Parts & Accessories Logo
472 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
