Question about Archos AV 500 400-Hours Video Recorder
Won't turn on
Battery fully charged, hold the on button, power light turns on, but not the HD light, Screen does not turn on... help please?
  • 3 Answers
I had this problem. I was mad. What I do now is not a "fix", it is a workaround. I hold the machine facing me, like I am watching it. I then twist it torsionally, top left corner away, bottom right corner toward me. It's like there is a crack in the circuit board or something. That works.
Posted on Jul 27, 2007
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
How do I turn on my ultratab C1059
The problem might be the battery. Please charge it full. If the battery is fully charged and still it won`t boot up, try this methods.
1. Remove battery, wait for a few seconds,
2. Reinsert battery.
3. Press and hold the VOLUME DOWNbutton,
4. Then press and hold the POWERbutton
5. Then release the POWER and VOLUME DOWN buttons
6. Press VOLUME DOWN to selectFACTORY RESET, and then press thePOWER button
Or this,
You can also use master reset. Hold down power button together with volume up or down button until you will see a screen in blue color with the logo>navigate and select wipe data/factory reset using your volume keys. Wait until your phone is completely rebooted.
Detached the SIM card to avoid contact deletion., likewise the SD card for file.
Jun 30, 2015 | Cars & Trucks
Asus 2-in-1 is on, but the screen is black and it won't do anything. I cannot turn it off either. What do I do?
The learning curve is vertical at these times.
Press and hold the power button for at least 15Seconds.
Dec 28, 2014 | ASUS 2-in-1 13.3" Touch-Screen Laptop -...
Wont turn on
Usually a reset does the trick. With the Kindle turned off, hold down the power button for 15 seconds. This will reboot the unit and should reset the settings which sometimes go out of sync like a PC does at times when the drivers don't start.
Aug 07, 2014 | Amazon Kindle Fire HD
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
HD camera.flip style
Did you do the Setup when you first started it? by holding the red button and following prompts? (to set up Language, date etc.) - if not try that. if yes, have you tried recharging it? Mine takes about 7 or 8 hours to fully charge (the red light will come on then when fully charged that light goes out) - it appears you have Ultra HD like me, so you should also be able to try some regular AA batteries in place of your rechargeable just to try that. If it works then, it is your rechargeable battery pack - either no good or needs charge. also when plugged into USB that red light should come on on front of the camera and if you look at the screen it should show a battery icon with a lightning bolt over it, shows the battery -how much charged. after 6 or so hours, press your red button and look at the screen - it now should be showing a battery icon that should by now be mostly Green and almost fully charged.
While charging the unit, Flipshare software comes up on your computer, "X" out of that software, so your camera will charge faster. My camera was doing similar things but I've had it a long time, and regular batteries worked, So I ordered a new battery pack and it has been fine since. Good Luck!!!
here is link to "what to do if battery not charging"
Jun 04, 2013 | Cameras
Phone won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 26, 2012 | Motorola Cell Phones
Lg101 cell won't turn on
5.Wait 10 seconds.
Step
Thanks
Jul 29, 2012 | LG Cell Phones
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Feb 29, 2012 | Toshiba Camileo S30 HD Camcorder -...
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Archos AV 500 400-Hours Video Recorder Logo
100 people viewed this question
Top Archos Televison & Video Experts
Inky Fingers
Inky Fingers
Jaime Hernandez
Steve Sweetleaf
Steve Sweetleaf
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
