Question about Lexmark X1270 All-In-One InkJet Printer
Me too! Help
I am having the same problem with the paper going to the left and just keeps pulling. then it yells it is Jammed. Can someone help us all.
  • 85 Answers
Are your side adjusters too far away from the paper edge
Posted on Nov 11, 2008
I'm getting a message stating Rec. paper jam slide platen left. Can you please help me someone donated this copy machine to the church however I need to repair it. Thank You!
after yoy slide, open up the cover and then you will see the cartridge (black color) then you pull out the cartridge (there is a holder steel).
and you will see the paper jammed.
take it all, do not be left one bit.
and then replace all like a before.
May 29, 2011 | Canon imageRUNNER 1370F All-In-One Laser...
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
PIXMA 450...Keep getting paper jam message and I can't see any paper bits anywhere. Trying to open the machine from the back to look inside. Have removed the 4 screws on the back and still can't remove...
Hi
The paper jammed can be found in the paper tray, remove the paper at the paper tray and inspect the roller for small pieces of paper jammed.
The paper can be found in the ink cartridge compartment, open the cartridge door and remove the ink cartridges, look for posibble paper jammer. Also once remove, check also the cartridge carrier if does not stuck up or jammed (cause this might me the problem). Turn off your printer and then move the cartridge head using your hand moving to the from right to left side and from left side to right side for 2-3 times. Move it gently.
Paper can be found in the rear access door if it is accessible. Inspect some paper jammed there.
Please let me know if you need more help
Mar 10, 2011 | Canon Pixma MP450 All-In-One InkJet...
I have several sheets of paper jammed in my printer and I can,t pull it out
Welcome to FixYa!
Don't try to pull out the jammed paper at the front panel of the printer. You might risk damaging your printer. Remove the jammed paper from the "Back Door" of the printer. The type of backdoor depends on what kind of HP printer you have. Below are 2 common backdoor of HP printers.
1. Press the Power button to turn on the printer.
2. While the printer is still on, disconnect the power cord from the rear of the printer.
3. Turn the printer so that the rear of it faces you.
4. Press in the tab on the left side of the rear door to release it. Then pull the door away from the printer to remove it.
5. Gently pull any jammed paper out of the rollers with your two hands.
6. Return back the back door. Gently push the door forward until it snaps into place.
7. Plug the power cord into the printer.
8. Turn the printer on again using the power button.
Note: Make sure to remove the jammed paper cautiously, any small pieces of paper left inside the printer might cause additional paper jam.
Some HP printers uses a latch to open the backdoor. Refer to the image below:
I hope that this will help you.
Thank you for using FixYa and keep me posted.
Jas247
Mar 09, 2011 | HP Office Equipment & Supplies
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
3900 series printer
Same with mine and when I try to look for more jammed paper, there is none. I have wasted an hour messing with it and I tried to call HP and they want $65 to talk to me because my warranty is out of date. Someone, please help us!
Aug 22, 2008 | HP DeskJet 3930 InkJet Printer
Paper feeder pulls paper incorrectly
A few possibilities exist: Look for something jammed in the paper path- by chance a paper clip, extraneous piece of paper, or even a broken piece of the printer itself. I'd guess there is a multi-section roller which pulls the paper, perhaps one section is slick- a tiny bit of oil or something on it. Something sticky (spilled pop) can goof things too. Anything amiss in paper path will foul up the paper feeding properly.
May 03, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Lexmark X1270 All-In-One InkJet Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
