Question about Canon Cameras
Camera is not connecting to PC despite it says DVI-IN. Can't read off Camera, tested on different computers and cables. Camera is a Canon MD225
  • 79 Answers
Hi there
Uninstall the camera software
Connect the camera
Turn it on
switch it to camera or playback mode
Open (my) computer
Look for a hard drive which wasn’t there before
double click it
Inside there will be several folders
One of them has your pics in it
Copy and paste them to wherever you want
Hope this helps
Beergut707
Posted on Oct 28, 2008
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
I have an AOC 22+ it is just a little over a year old (just out of warrantee) When you turn on the monitor and boot the computer the monitor will go thru its start up showing the AOC logo then it goes...
unfortunatly i believe the monitor may be dead. also check the connection on the monitor itself (the cable) some of these monitors are picky about which port is active dvi or vga there should be an option to change the input on the monitor itself from vga to dvi for the connection i hope that helps let me know!
Mar 14, 2011 | AOC V22 22" Monitor
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
Pc says camera is busy
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 11, 2010 | Canon EOS Rebel XSi Digital Camera
My pc does not read pics from my canon sd 630
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Jan 07, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
How do i connect my compaq pc to tv
Without the model number comptuer, I cannot verify what outputs your comptuer has. Without this, I will provide the various ways a PC can be connected to a TV.
1. Use a VGA to DVI adapter (HD-15 pin to DVI). Use either a standard VGA montor extension cable (cheaper) or a DVI extension cable (more expensive) to make the connection
2. If you computer has a DVI output, use a DVI extension cable only
3. If your computer has HDMI output - use a HDMI to DVI adapter and either a HDMI or DVI extension cable.
In all 3 cases, you will probably need to go to the comptuer's Display Properties and adjust the screen size so it looks OK on your TV (go to the Control Panel - find Display) and adjust the screen resolution to match the format of your TV.
One note - when purchasing DVI cables, understand that there are 3 types - DVI-D (digital), DVI-A (analog) and DVI-I (digital and analog) and that the pin outs are different. Be sure to check your the owners manual of your TV to find which connection it needs.
Here is a good reference for DVI types
http://www.interfacebus.com/Design_Connector_Digital_Visual_Interface_DVI_Bus.html
Dec 02, 2009 | Compaq Computers & Internet
How do i connect advent pc to philips hdtv. do i need to change settings?
well not really, you need to buy the proper cable depending on the inputs of your tv, it may have the standar VGA connection as the standar pc monitor.
DVI to VGA cable
DVI to DVI
HDMI to DVI
HDMI to HDMI
after you have the proper cable just plug it, and turn it off, disconnect the standar computer minitor and turn it back on. the computer will set the input signal from the tv by itself.
thats for the video, for the audio you need a different cable
3.5 mm to RCA (white and red cable)
3.5 mm to 3.5mm headphonejack cable
but if you are using the HDMI to HDMI you don't need a sound cable.
Oct 07, 2009 | Computers & Internet
I cannot connect the camera Canon MX2 to pc. I used DV cable and USB
test it by connecting the unit on a different pc. test and see if there was a problem on the data cable you are using.
Jul 08, 2009 | Canon DM-XM2 Mini DV Digital Camcorder
Problem is following - computer can't detect canon cameras, i mean eos and powershot a590is. drivers are installed from solution disk, included with powershot /v.33.0/. nothing works, not cameraWindow, nor...
TRY TO USE A DIFFERENT DATA CABLE, OR BETTER TEST THE CAMERA BY CONNECTING IT TO ANOTHER PC, THIS WAY WE WILL KNOW IF YOU HAD A PROBLEM WITH YOUR DATA CABLE OR YOU PC,
Jul 08, 2009 | Canon PowerShot A590 IS Digital Camera
My computer is not recognising my EOS 20D!
Hi I have exactly the same problem. I'm running Windows Vista Business as the OS and have installed the disk that came with the camera with no avail.
It keeps recognising it as a scanner, but I cannot open the pics. I've tried different cables as well. No use.
Mar 11, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Cameras Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
