Question about Avanti Refrigerators
Freezes everything on any setting freezes
  • 2 more comments
  • mike Feb 25, 2012
    compressor kept running and there was not and damper door. the thermostat would not cycle the compressor off thanks for the help
  • danny Hendrickson Feb 26, 2012
    hi poolshark435, can you send me a model number of this avanti unit,as this is not a large item in my area,sorry about the mis-information earlier
  • Cathie Currie
    Cathie Currie Aug 02, 2012
    Mine freezes at minimum setting too. It is Avanti. Seems to be discontinued in Avanti brand, but , but is the same as: CRF150SS - EdgeStar 1.1 Cu. Ft. Stainless Steel Freezer w/ Lock - Stainless Steel
  • Cathie Currie
    Found the Avanti model#: Avanti RF171PSS 1.4CF Convertible Refrigerator Freezer w/ Lock.This is a compressor model.
    President:
  • 2,468 Answers
Check the damper vent door that throttles cold air into the refrigerator compartment from the freezer compartment,ifd its frozen or stuck or even broken it cant close to keep cold air out of refrigeerator compartment when it reaches the temperature you set it at
Posted on Feb 23, 2012
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
Why does Our refrigerator keeps freezing everything? Even the food in the drawers are frozen. Why is that?
Check the cold control thermostat setting maybe you set it to max. put both controls on middle of whatever numbers you have on them and if its already on middle or at minimum setting still it freezing everything you need to replace to Cold Controller Thermostat
Aug 23, 2014 | Jenn-Air JCD2295HES Side by Side...
JCD2290HES Side by Side Refrigerator: my jenn air side by side is freezing everything an...
i have the same problem i clean the coils and work for two weeks and now is freezing need solution thanks
May 16, 2010 | Jenn-Air JCD2290HES Side by Side...
I HAVE A AMANA ARB2517C THE REFRIGERATOR KEEPS FREEZING EVERYTHING I HAVE TAKEN EVERYTHING OUT OF THE FREEZER AND FRIDGE AND LET IT THAW OUT AND WHEN I TURNED IT BACK ON WITH THE SETTINGS SET ON 1 OR COLD...
Your defrost system has gone out and it will continue to freeze until you replace it.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 Am until 9 PM CST and we will get the correct defrost system out to you asap.
We look forward to working with you. Thanks, Ella
Nov 13, 2009 | Grilling
Frigidaire refrigerator freezes everything with setting on lowest
hello there,
try to check your thermostat setting adjust below gradually,
you set it up to coldest point that's why it's doesn't cycle on no auto shutt off and shut on,
if still not change for 12 hours still freezing up,replace thermostat by your technician,might defective.have a nice day
don't forget to rate me,thank's a lot.
May 05, 2009 | Frigidaire FRS26H5AS Side by Side...
New 700BR freezes everything in it. Worked ok for
Sounds like a stuck thermostat, you can try to tap it and this may "unstick" it, or you would need to replace it.
Mar 09, 2009 | Refrigerators
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Refrigerators Logo
451 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
