Question about Poulan Pro PPBP300 30cc 2Stroke Gas Powered 180 MPH Back Pack Blower 952711971
Why does it idle fine and then when you give it gas it boggs down
  • 885 Answers
A two-stroke engine idles because a very small hole behind the throttle plate lets a tiny amount of gas through to keep the engine running. At full throttle the air moving through the carburator pulls gas through the venturi vaporizing it. With the motor at idle, if you give the motor full throttle very fast the first charge or two that get into the cylinder are almost completely fresh air with vary little or no gas mixed in. It takes a revolution or two for the motor to pull air through the carburator fast enough to get a fully charged mixture of gas and air into the cylinder so you get full power. This effect is especially pronounced when the motor is cold, the gas doesn't vaporize as well when the motor parts are cold. If you give it throttle slowly or let it warm up the effect should go away.
Posted on Feb 23, 2012
76 jeep cherokee 360. how many turns on the oxygen screw of the carburator? i can take off fine if i baby the gas but if i give it too much gas it boggs down and back fires.
Sounds like a problem with the accelerator pump or cruise circuit in the carb. The idle mixture screws only affect the idle circuit.
You start with 2 turns out then adjust it with an exhaust gas analyzer.
Sep 29, 2013 | Jeep Cherokee Cars & Trucks
Idles but Boggs down when u give it gas
Hi Anonymous, if you have a carburator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Good luck
May 31, 2012 | Harley Davidson FXD Dyna Super Glide...
My 89 blazer boggs or dies
check all your vacumm hoses, I think you may have a hole in the air intake hose to the engine, sometimes the hole is underneath the hose so feel around...goodluck!
Jun 15, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Ford pickup loss of power
did you run a fuel cleaner?
Jun 10, 2008 | 1994 Ford Ranger Supercab
Poulan Pro PPBP300 30cc 2Stroke Gas Powered 180 MPH Back Pack Blower 952711971 Logo
377 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
