Question about Home
Type moon 433 sterling
How do i reset this alarm system, as when i open it, the car alarm just goes off. tha ks for helping
  • djdevilnight Feb 23, 2012
    Ok guys fixed it, what you have to do is, usually it might be mixed up with your other standard alarm, you can tell this by listening to 2 different tones of the alarm. Make sure the locking sequence is correct I.e. when car is locked remotely using aftermarket keyfob the indicators flash twice. Now using the after the original key twist it inside the key hole and look for that sequence 2 flashes they both should be in sync if you know what I kean
  • 12 Answers
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Posted on Jan 15, 2009
  • 232 Answers
SOURCE: anti theft will engage
Try disconnecting the positive from the alarm. Sometimes its connected straight to the battery. If its not connected to the battery look underneath the dash drivers side. Find the alarm brain, the power cable (RED) should have a fuse on it. Take the fuse off, disconnect the negative from the battery wait five minutes. Then connect everything, if you took off the right fuse the alarm should restart. If its still doing it the alarm is not the problem. If you have a trunk switch to the alarm, you can simply disconnect it. These switches are optional and often get corroded or defective almost always causing the problem described. After disconnecting the negative from the battery you might notice your car's driveability different. This is because the car's computer also gets restarted. Don't mess with anything in the car the computer will set on its own. Let me know if you still have a problem after this.
Posted on May 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: lost original car alarm control... need to reset a new one...
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try.
Posted on Oct 29, 2009
  • 39 Answers
SOURCE: remote does not open doors
have u checked and replaced the battered in ur alarm/central locking fob ??
Posted on Jul 13, 2010
SOURCE: 1999 Toyota Avalon, key fob locks doors, but will
hello the identical thing is happening to me did you find out what was wrong? regards Ellen
Posted on Oct 11, 2010
Changed battery in the remote starter and now won't open doors or start the car
Possible it may need to be set up again. If you take it to where it was installed I am sure they will set it again for you without a charge.
Jan 26, 2016 | DSC Rf5501-433 Powerseries Wireless...
How can I turn off chimes?
Read your manual; I do not provide any info regarding alarm system disarming questions etc...
Jun 06, 2015 | DSC Rf5501-433 Powerseries Wireless...
HOW do you programme a toad immobilser fob
Contact the company that sold you the fob and request the directions they were supposed to include.
Jun 29, 2013 | Fiat Cars & Trucks
1998 Catera, the alarm system started to sound and I don't know how to reset it, or what set it off. We had the car sitting out all day, waxed it, left the windows down, and when we opened the door the...
there is no reset, whenever you turn the igntion key to on or unlock the door with the remote or the key the system is disramed, if it goes off like you have going on a sensor in the system is defective and you will need the dealer to scan the system for the fault.
Sep 30, 2010 | 1998 Cadillac Catera
After disconnecting the battery and then reconnecting it on my 2000 Toyota Tacoma, the alarm goes off and the car will not start. I do not have a remote for this car and need help in a course of action. I...
If after unlocking the driver door with the key and still no luck, put the key in the ignition and turn forward to start (if it won't start turn forward anyway) then push you're red reset button on the dash. That should do it.
Jul 10, 2009 | 2001 Toyota Tundra
I have a thatcham TE2-1331/0305 I want to fit in my car but need a wiring diagram STERLING EXCEL THATCHAM TE2-1331/0305 ALARM IMMOBILISER Neil .
My 2005 Dodge Caravan head lights and dome lights stays on a little longer then the norm. Also the chime indicator that lets you know that you left the lights on or you left the keys in the ignition comes on as soon the door is open.I have had one battery go dead on me . Can't afford to be replacing batteries when they go dead on me! Can you help?
Jun 11, 2009 | Anti-theft Alarm System 3 Series E90 E92...
Toad sterling car alarm lost manual and need stop code.
This worked on my car when the clicker died:
Put the car in valet mode. Disconnect the NEGATIVE battery terminal. Put the keys in the ignition and turn it as far forward as you can (as though trying to start it) and let it spring back. Reconnect the negative terminal. This should reset the alarm to valet mode. Programming varies from brand to brand. Contact an alarm dealer and they can help reprogram the remote(s).
Oct 17, 2008 | Vehicle Parts & Accessories
Home Logo
171 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
