Question about Electrolux Washing Machines
I have an Electrolux front load washer. It is reading "clean tub." What does that mean?
  • Electrolux
    Electrolux Feb 24, 2012
    This is actually telling you that you need to follow the "cleaning" cycle in your owner's manual to have the unit go through a self cleaning cycle.
3 Suggested Answers
SOURCE: i lost my manual for
Here's a link to the manual:
http://www.electroluxappliances.com/Files/Documents/Use%20and%20Care/EIFLW55H_uc_EN.pdf
Posted on Aug 23, 2010
SOURCE: my front load Electrolux washer asks me "clean
You do not need to clean a drain pump. After you have washes so many loads of clothes, soap scum builds up in your tub and will shorten the life of your product. You just need to run it thru the "clean" cycle. You can use 1/2 cup of bleach and NO detergent or you can by a tub cleaner from most grocery stores or Walmart and use that. It'll just remove any soap scum and mineral build-up off your tub. It should be done each time you washer tells you to do it. Hope this helps. :)
Posted on Sep 22, 2011
What is electrolux front load washer E58 error code
Good Morning Friend, I am happy to assist you!
I understand your Electrolux washer is getting an error code E58. It could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Hope this helps! - Z
Jun 04, 2014 | Frigidaire Affinity ATF7000E Front Load...
Load noise and will not spin out clothes
Good Morning PJ, this is AP with Electrolux.
Thank you for submitting your question concerning your Frigidaire front load washer, ATF6000ES. Typically if your washer is making a banging noise it could mean one or two problems, but primarily the tub is off balance or your washer is not level. In this regard, since the tub is spinning it would be advisable to reach out to a local service provider to properly diagnose your washer. You can often locate a qualified tech through the manufacturer website.
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
Electrolux front load washer leaking bleach onto floor
may be u use diff soap? check ur soap if is for front load or top load?
if soap is correct but still leak its means the hose or tub is have crack and coz of leaking.
call the technician for your safety and not to waste money.
Oct 31, 2013 | Electrolux EWFLW65HIW Front Load Washer...
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
My front load Electrolux washer asks me "clean
Aug 03, 2011 | Electrolux Washing Machines
Water was not draining from tub. Read to remove front panel and clean out the filter. How do you get front panel off without denting machine?
Electrolux in their wisdom seem to have discontinued the lower front access panel.To avoid removing the complete front panel You can try this: Remove the back-panel and try to remove the clamp which holds the Hose( coin trap, tub-to-pump) to the tub. If the clamp is a spring-type and You can't reach the end to decompress it You can tilt the washer to the right side(seen from the front) and reach it from underneath. It worked for me.
Mar 09, 2011 | Frigidaire GLTF2940ES Front Load Washer
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
I have a new electrolux front load washer. When
Mine only smell mildewy if I leave them in more than an hour before drying. My old top load washer did the same thing. I dont wash unless I can immediately switch to the dryer.
Nov 24, 2009 | Electrolux EW1000i Front Load Washer
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
