Question about Sony Playstation 3 (PS3) Console
Ps3 says ip address timed out / wep key was entered incorrect.
So i turned on my ps3 and it said i had to check network connection in seetings. i tested the connection said ip timed out. and another time it said that and wep key was entered wrong. but the wep key is right and ths ssid is correct. signals 100% my xbox 360 and wii connected just fine and hae been up and running with no issues . i rebooted the router and modem. changed the ssid and password to see if that was the issue . wasnt then i set ps3 to factory spects. not shure what to do. called inter net company and router nothing they can help with.
  • Cathryn Evans
    Cathryn Evans Feb 23, 2012
    issue was fixed .. changed the channel of the router, changed beacon intervals 75,Change the Fragmentation Threshold to 2304,RTS Threshold to 2304 and then Under Security tab,uncheck "Filter Anonymous Internet Requests" and saved it all. ps3 showed every thing as succed.. yaaa it works agin.
  • Cathryn Evans
    New Friend:
  • 10 Answers
Have you tried manually adding a IP to your PS3 ie if your routers ip address is 192.168.1.254 set your PS3 to 192.168.1.60, with a subnet of 255.255.255.0 and set the gateway to the IP address of your router in this example it would be 192.168.1.254..
Posted on May 05, 2017
3 Suggested Answers
  • 258 Answers
SOURCE: Network connection problem with the ps3
You need to check the settings on a connected device see instructions here:
http://www.howtofixanything.co.uk/howto-howtosetupaps3withastaticipaddress.html
Posted on Jan 16, 2009
  • 10 Answers
SOURCE: wont connect to wi fi
This used to happen to me alot when connection was bad due to distance form the router. If your router is far away, find a way to move it closer. Reset the connection settings on the PS3 and do automatic search then just enter the WEP again
Posted on Jun 16, 2010
IP adress timing out on my PS3
you could try putting in the ip adress manuley.to get you ip adersses go to cmd prompt in cmd prompt type in ipconfig/all .
Jan 08, 2010 | Sony Playstation 3 (PS3) Console
Had my ps3 for year and half now, never played online (80710102)
Ok first off create a psn account online via computer, this is free of charge. Then after that connect your ps3 via cable to your modem. turn it on and access network settings. Then select internet connection settings, select easy. After it is finished select test connection. Should this time out it means you have a faulty connector somewhere, try checking your cables and the ports on the ps3 and modem. But if it states connected, back out and go to network via your ps3 dashboard then select sign in and enter your account info from your psn account.
Dec 08, 2009 | Sony Video Game Consoles & Games
I cant get my ps3 to go past the ip address stage on the sinal test part on the ps3 it comes back as a fail or a time out???
firstly, try to connect with an ethernet cable, if no joy, are u using a pc on the network? check your firwall settings, is uPNP enabled? check port forwarding on your router, can your ps3 connect to your network?
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Cant connect my PS3 to internet
you can test your internet speed here http://www.ip-details.com/ ,i test my internet speed and got good result, this provides th ep details at free of cost ,i test the ip details here..
Nov 11, 2009 | Sony Playstation 3 (PS3) Console
My psn is timed out????
check the IP configuration of the playstation to make sure it is similar to what you have on yoru PC
Aug 13, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Playstation Network timed out
try moving ur ps3 closer 2 ur router dat should make da connection stronger. but another thing is wen da internet router is used by too many appliances certain ones for example ur ps3's internet becomes weaker. i hope dis helped=)
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 keeps on saying ip timed out
your ip settings are most likely wrong, check your desktop pc settings
here is how
start -> run -> cmd -> ipconfig
note, ipaddress, subnet, gateway
if your desktops ip is similiar to 192.168.1. 2 to 254
then set your ps3's ip as 192.168.1.25 for example
just a number between 2 and 254 (the 1 is used by router) witch isnt used.
your address might show 10.0.1.20 for example or a more complex ip like 86.32.55.100 if this is the case set the ps3 on automatically get ipaddress and dns server.
if you need any help let me know. Good luck.
Apr 02, 2008 | Sony Playstation 3 (PS3) Console
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
175 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
