Question about Water Heaters
Worcester 24i rsf luke warm water - Water Heaters
  • 234 Answers
SOURCE: worcester boiler 2 years old keeps loosing pressure
http://www.worcesterbosch.com/Go there see if you can get some help.
Posted on Mar 19, 2009
  • 234 Answers
SOURCE: wiring diagram worcester 24i junior
http://www.worcesterbosch.com/ gothere and see iu get help for what you want.
gary1121
  • 332 Answers
SOURCE: Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
Posted on May 30, 2009
  • 150 Answers
SOURCE: worcester 24i combi when in shower hot water
This is lack of water flow through the diverter valve.
First have you got a good flow from any cold tap? If yes then see below
If I remember there is a pipe carrying cold mains crossing the lower front of the boiler with an in line filter usually clogged. Remove clean & replace
check also any filter in rising mains to boiler
another cause is the diverter valve itself - diaphram inside may be punctured/split
Posted on Sep 02, 2009
SOURCE: My boiler is not working, not heat, no hot water,
your condensation pipe may be frozen get a hairdryer on it or a hot kettle that should sort it thats the whit pipe on the left usualy plastic
Posted on Jan 09, 2010
Worcester 35cdi water and heating luke warm
First thing is to know when it was installed? Check the top of the unit and see if it has in and out marks on it. If it does are they correctly hooked up? Installing them backwards causes this.
Jun 04, 2013 | Water Heaters
THERE IS NOT IGNITION. IT SPARKES BUT WONT LIGHT.
sounds like your not getting gas...maybe a vapor lock,,,,,,,make sure you are compressing the pilot button all the way.....try to listen and see if you hear gas flowing....
Jan 19, 2013 | Bosch Worcester Spark Electrode...
Pilot light ok when release finger pilot goes out
Your thermo couple is bad. Thats the copper tube that goes from the gas valve to the pilot. It senses thats the pilot is lit. Thats not working thats why it goes out. You can get a new one at lowes or home depot for about ten bucks its pretty easy to change just dont kink it when you put it in. It will just plug in at the pilot and screw in at at gas valve.
Jan 11, 2013 | Bosch Worcester Spark Electrode...
Replaced diverter valve on worcester 9.24 combi and still only luke warm water
check your expansion vessel is not flat.if so recharge..simple way to check press in valve on vessel if water comes out or little air recharge..if water still in vessel the diaphram in vessel has split so replace vessel?hot water relys on expansion??
Dec 10, 2012 | Water Heaters
Hi where can i find a manual for a worchester greenstar 24i junior boiler please
if you go on the worcester bosch web site and contact the service dept they should send one out to you or you may be able to download one from there.
Mar 27, 2009 | Water Heaters
Wiring diagram worcester 24i junior
Mar 17, 2009 | Water Heaters
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
