Question about NetGear Computers & Internet
I need to set up a code to keep other people from using my internet from my router N150 Netgear
N150 WNR1000
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Try reseting your router (RESET button on the back) then enter 192.168.1.1 in your browser. User is admin, pass is 'password'. Here, on the conf screen you can change everything you need, including the password, so everything should be much more safer to use. If you need a complete step by step guide on how to use it, you can always check this great users manual. It really helped me a lot. Hope that it will also help you. Good luck! :)
Posted on Dec 09, 2013
  • NetGear Master
  • 32,281 Answers
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Feb 26, 2012
  • 556 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
Are the router addresses assigned on the same subnet?
many routers have a base address of 192.168.0.1 and a subnet mask of 255.255.255.0 meaning all addresses 192.168.0.? are part of their network.
One problem can be that both routers can be using the same subnet -- not an issue if they are connected to different connection points (such as two different houses) on the internet. However when connected to each other in your house they are confused because they have the same two different networks with the same addresses. -- for slightly different reasons --
For those that want you to connect from one router to the wan of the other you need to assure the base addresses are in different subnets -- assuming the one connected to the internet is addressed as 192.169.0.1 with a subnet mask of 255.255.255.0 his network as stated before is all addresses 192.168.0.?. Change the second router to a base address of say 192.168.2.1 with a subnet mask of 255.255.255.0 his network is everything staring 192.168.2.? they are now different and it should work. On the wan side of the router you can assign a unique 192.168.0.? address not in the DHCP range of the first router or accept a dynamic IP address from the first router. The dynamic address is probably the easier and less problematic of the solutions.
For those wanting you to connect to a lan port and ignore the wan port they should also have asked you to turn off DHCP in the second router (where you do not use the wan port) and allow the first to do all the dynamic network address assignments. In this case you could have two DHCP servers on the network competing to assign possibly the same network addresses -- if they have overlapping ranges duplicate addresses could be assigned resulting in device connection issues for those with duplicate addresses. Even in this case you may need to assure the gateway addresses are unique on the network ie of both routers are addressed as 192.168.0.1 the second where the WAN is not used could become 192.168.0.2 (where that address is not in the active DHCP server's assignment range) or 192.168.2.0 (note the DHCP server had better be off or else the empty wan port 192.168.2.0 could become the "gateway" address of attached PCs and since there is no connection there will be no access to the internet.
I hope this helps
It is quite likely either solution could work if all the proper changes were made.
Posted on Dec 15, 2007
TBlessed 1
  • 61 Answers
SOURCE: Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Posted on Dec 01, 2008
  • 8404 Answers
SOURCE: my daughter is trying to install the netgear n150
You do need a modem ... the tech probably put one in. I say this because you say there are phones, tv and internet involved. There must be a modem somewhere.
You must run ethernet from your router to the modem.
Tell me more, maybe I can give more help
a
Posted on Oct 14, 2009
govinda123
  • 2260 Answers
SOURCE: Setup for Netgear N150 Wireless Router WNR1000 requires log in.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Feb 26, 2010
Testimonial: "Your suggestion led me in the right direction. Thank you. "
SOURCE: unable to configure belkin n150 router manually
while connected to router, open internet browser and enter 192.168.2.1 into the address bar. this opens most belkin router setup utilities.
Posted on Mar 04, 2010
What is wep/wpa key for netgear n150 wnr1000 router?
By default, there is none. If you set it, it will be set to what you put in. If you dont know it any more, you can reset the
Aug 23, 2014 | NetGear Computers & Internet
Anyone can use my internet how do i set up security code i have netgear wireless 150 wnr1000 router how do i fix this everyone using my enternet
You need to configure your router with wireless encryption.
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 01, 2013 | NetGear Computers & Internet
The saved settings on my laptop for the network do not match the requirements of the network,what do i need to do ?
First, delete the SSID and saved settings in Network and Sharing Center. I don't know your OS?. Then reboot the machine, Your wireless will show your not connected but wireless networks are available. Select your SSID, enter your "password", connect. dependind on your OS, a popup will ask to auto connect and save settings.
Dec 31, 2012 | NetGear RangeMax N150 Wireless Router...
Belkin N150 Wireless USB Adapter is not connecting to Netgear WNR1000 N150 Router which requires secured access. Was working fine before with "Network Authentication: WPA-PSK" and "Data...
Put all your settings back to the way they were and check the time and date on your computer (also on the router), WPA uses encryption, if the time difference between the two is too great it can break the encryption (seen this often).
Mar 10, 2017 | Belkin N150 (F6D4050) 802.11g/b Wireless...
Net gear wireless router N150 router WNR1000
Looking for the NETGEAR WNR1000 default password?
You probably have little reason to access your router on a regular basis so don't feel too bad
f you've forgotten the WNR1000 default password.
However, when you're troubleshooting a network problem and need to get in to the device,
the WNR1000 default password suddenly becomes very important.
For most versions of the NETGEAR WNR1000, the default password is password. As with most passwords,
the WNR1000 default password is case sensitive
Be sure to change the default router password on your WNR1000 to something more secure as soon as you're in.
Then use a free password manager so you'll never forget your new WNR1000 password
hope this helps
Jul 25, 2012 | NetGear WGR614 Wireless Router
Connecting netgear n150 to nintendo ds
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Jun 06, 2012 | NetGear N150 RANGEMAX 150 Wireless Router
Can I set the WNR1000 as an access point
Yes, You can set it as a wireless access point. All you need to do is follow the steps below.
1. open internet browser, enter on the address bar http://routerlogin.com
2. username is admin, password is password.
3. Go to wireless, change the wireless settings like the ssid and setup the encrption. Go to LAn settings under advance.
4. Disable the dhcp server and change the ip address of your WNR1000
ex. You plan to connect your wnr1000 to a w ired route rwith an ip address of 192.168.1.1. You can set the wnr1000 to 192.168.1.x ( except 1)
Save the changes,
Plug the access point wnr1000 to the lan port on the main router and the other end also on the lan port on the wnr1000.(LAN to LAN)
It should be working now as an access point.
Kevin
Jul 03, 2010 | NetGear WNR1000 Router
Computers & Internet Logo
71 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
