Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel ecosmart GWL11 fill problem
I have a Fisher & Paykel ecosmart GWL11. Several weeks ago, the following problem appeared. During the initial fill cycle (Phase 1, Eco Active Wash), the clothes become saturated with water, and then during the recirculation phase, there is insufficient water for the pump to recirculate the water without cavitation of the pump. Water is recirculated in spurts, and the pump sound changes (every few seconds). This continues for about 4 minutes, and then the fill continues to a normal fill level to Phase 2. I'm afraid this will ultimately damage the pump. What is your recommendation?
  • Fisher and P... Expert
  • 555 Answers
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Posted on Dec 26, 2013
4 Suggested Answers
RescueTech
  • 145 Answers
SOURCE: fisher paykel gwl11
Hi Alan.. usually if there is a problem where the diverter valve is not sensed by the machine control, it will throw a fault code and beep and not complete the cycle. There should be a tech sheet under the control panel. Did you make sure you properly re-connected the two orange wires on your new diverter valve?
I certainly have encountered several over the years where the control stops puting voltage to the diverter in recirculate mode.
If you want to be able to use all the cycles on the machine, then you need a new control board. That is part #420094USP and can be purchased from Fisher Paykel Parts direct;
http://fisherpaykelparts.net/index.php?categoryid=111&productid=26
If you need to do laundry in the meantime, use the PERMA PRESS wash cycle, it should work for you, as that cycle does not use the diverter valve.
Also inspect your water pump and make sure it isnot wet or leaky, as this can cause the machine control to either short out altogether or lose functionality on some cycls such as you are experiencing.
I hope this info is helpful to you.
Posted on Dec 15, 2008
SOURCE: Fisher Paykel gwl11 washer leaking and squealing
Set the machine on its side and started taking it apart til the problem was obvious. Called Fisher for the parts. A big black seal is out and a bearing above the impellor that cools the motor, we ordered a pump assembly that is on the bottom side of the motor. I am still going to replace the water pump in the drain side, that is a no brainer. Will update on the repair when the parts arrive
Posted on Jun 02, 2009
I have a GWL 11. Bought the washer and dryer and the same time in Feb. 2006. Dryer fell apart Feb 2009. 3 weeks ago the washers diverter valve failed, I ordered a new one and recieved it, washed one load of clothes and the drain pump failed, order it and have been waiting 2 weeks for the drain pump. They still do not have it in stock, Fisher Paykel or Sears. Tomorrow I go buy a Kenmore or Whirlpool.
Posted on Jun 05, 2009
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Fisher and pykel EcoSmart won't start
You can find a service manual at the link below to assist in repairing your machine.
Download the smart drive mw511 manual
Link:
Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
Oct 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
Our gwl11 fisher paykel washer will start to fill for about 5 seconds then stops
This is either your lid switch not working or your out of balance switch the latter being located under the large motor controller board under the controll panel.That should fix it.Kind Regards Stefan.
Jul 08, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel ecosmart purchased 3-4 years ago.
I too am having this problem.  I am checking out if anyone has a solution.  Somewhere someone said to change the "Fill switch"  I don't know what that is or where it is.  Does this help?  If you have found anything let me know. monica.roberts@usa.com
May 23, 2008 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel washer - manufacturer in October 2005
Please follow link Might require free sign up.
According to my experience it sounds the your pump is blocked or outlet of water obstructed.
Normally when pump cant be activated you get this problem.
May 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
May 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
325 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
