Question about Refrigerators
Kenmore Refrigerator 106-9557612 Ice Maker won't Eject cubes
My ice maker fills with water. The water freezes completely.
The heating element beneath the ice tray gets hot. The Ice cubes never eject. Problem began about a week ago. I have removed the ice maker, thawed it out to remove the cubes. re-installed the ice maker Same results.
  • 1 more comment
  • calleycatz Oct 28, 2008
    Thanx for the advice Mca0834. Are there any additional checks I need/can to do to confirm the bad motor? Do you also have the entire ice maker? What is the cost of the whole deal + Shipping?
  • Anonymous Mar 26, 2009
    seems like mine dispenses too much water.
    it will kick out the cubes but they are hooked together with a heavy layer of ice above them and when the unit pours in the water, a surplus runs over the top into the bin of cubes below.
    does the unit dispense the water on a 'timed' period or in some way judge how much water has poured in??
    genehitz@gmail.com
  • Anonymous Mar 16, 2014
    Ice maker producing ice cubes but it all freezes together
  • 172 Answers
Hi caleycatz,
It sounds like you are in need of a motor module for your icemaker. This is the motor and gear that drives the icemaker prongs. The part number is
W10190935 The price is $77.59 and $6.00 shipping
I can have one of these at your door in 1-2 days, so let me know if you need one. We take Visa Mastercard and Discover. Or you can order from sears for the same price and wait 10 days.
Good luck to you and I really hope this will FixYa. Please take the time to rate me. Thanks
Mike Anerson (Owner)
Anderson Appliance Repair
(865)945-3808
Mca0824@aol.com
Posted on Oct 28, 2008
Ice cube ejector bar keeps freezing preventing ice from ejecting to tray
Replace your water valve part # WR57x10032, from what you have listed above you have a bleeding water valve allow water to enter the ice maker mold. The valve is not closing completely. This part show fix this issue for you.
Good Luck
Mar 30, 2014 | General Electric GE GSS25GFXWW (25.0 cu....
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The coil directly beneath the ice container is burning hot. What should we do? Is this normal.
you mean the coil beneath the ice cube maker tray?? yes that gets hot every time the ice maker gets ready to eject the ice. it heats the metal tray a little so it melts a thin layer of ice to allow it to release from the tray easily.. now if it is staying hot all the time then the ice maker head, or if thats not available the entire ice maker can be replaced..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Too much water is being dispensed when filling to make ice cubes. Water pours into ice bin and freezes. What to do?
You have to close the water supply tap from the source a little. This will decrease the volume of water being pumped into the ice maker. If this doen't work then you need to replace the solenoid valve that feed the water to the ice maker.
Jul 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Apr 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice Maker Infrared light doesn't light
Each mold tray has a heating element that is turned on to free the ice cubes from the mold tray and allow them to fall into the ice bucket when the tray is rotated into harvest position. Sounds like that is not being turned on... or is defective..
Sep 18, 2008 | KitchenAid KSRG25FK Side by Side...
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Refrigerators Logo
410 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
