Question about Fossil Casual Metal Anadigi Silver JR9306 Watch for Men
Set time and date on my fossil JR9306
I CANT SET TIME FOR 12 HOUR TIME
  • 4 Answers
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Posted on Dec 02, 2008
escapement
  • 2334 Answers
SOURCE: No manual how do I set time?
You have to open caseback and upload the movement number here. Then I might help.
Posted on Dec 19, 2008
  • 2501 Answers
SOURCE: how do I set the date on my Fossil AM 3108 watch
Try their web site. Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html . You will find a set of instructions; choose the ones for your watch and download.
Posted on May 12, 2010
Testimonial: "Thanks for such a great & quick answer "davidtolond". You've been extremely helpful."
mcdevito75
  • 1970 Answers
SOURCE: trying to set the time
mcdevito75 here, Press the mode button, you may have to hold it down a couple of seconds, once you see the display flashing press set for each function, after each function is set press mode to move to the next function, hour, minute, day etc. Once all functions are set press mode for steady display. NOTE, the mode button could be a small dimple not far from the winder crown, use a tooth pick to presss this dimple in.
Posted on Nov 19, 2010
  • 93 Answers
SOURCE: How to set or restart
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
Posted on Dec 14, 2010
My Watch is showing military time but i want it to show in the 12 hr clock
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
http://www.fixya.com/support/t6812987-change_timex_wr30m_from_24_hour_12
How do change my timex wr30m from 24 hour to 12 hour display
Mar 21, 2018 | The Watches
I Have a fossil 10 atm watch & the date doesn't change automatically so i change it manually but then half way thought the day it changes the date
Your watch is 12 hours out of step.
The date changes every second time the hour hand passes 12 O'clock.
Your watches' second pass is at midday instead of midnight, so to make it operate correctly, you need to wind it on 12 hours. The date will then change at midnight.
Jul 13, 2011 | Fossil Watches
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
Dec 14, 2010 | Fossil MultiFunction Automatic ME1030...
My me1020 came without instructions and i do not know how to set the date, min nor theday please help
Actually there is no instruction manual for ME1020 available on Fossil website except for how to replace the battery. When you try to match ME1020 model with the available diagrams, there is no match (4 eyes). To set the time, pull the crown out to the second position. Now set the min/hour hands. Date hand is linked to it so keep rotating the crown till the date is set is set correctly. Now remaining is the day setting. Notice that the day changes every 24 hour mark on the 24 Hour sub-dial, so cross this mark to change the day. Go reverse & again cross the 24 hour mark to get the next day. Repeat this till you get the correct day setting. Now your day is also set along with date & time!
Feb 14, 2010 | Fossil ME1020 watch
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
How do I switch from 24 hour time to 12 hour time?
Hi greg780,
Hope it helps.
Thank you for using FixYa.
Oct 12, 2009 | Timex 1440 Nylon watch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
Hope it helps.
Oct 09, 2009 | Timex 1440 Nylon watch
Dec 18, 2008 | Fossil Digital Sport Hologram Display...
Setting the month,day, and date.
Alot of times on watches you can click on the stem one time and you can change the hour. Click on the stem and you can change the minute, date, and month.
Jan 04, 2008 | Watches
Fossil Casual Metal Anadigi Silver JR9306 Watch for Men Logo
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
