Ricoh SP C420DN. Cannot reset maintanence counter. Everything is brand new. Tried unplug and replug. tried to reset in SP mode. No luck
Ickoajnc
  • 183 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
  • 114 Answers
SOURCE: When it prints it only prints garbled letters
usually when it prints Garble it means the wrong driver is installed for the printer or PC. Make sure you have the correct driver and unistall the one you have and reinstall the new one.
Posted on Mar 21, 2010
  • 903 Answers
SOURCE: Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
Posted on Jun 05, 2010
  • 903 Answers
SOURCE: i have ricoh laser printer
sc270 is an error with the shutter on the laser unit. Turn the machine completely off and then back on -- if the error doesn't clear, the shutter sensor or motor will likely need to be replaced.
Posted on Mar 06, 2011
Joed911
  • 4338 Answers
SOURCE: I am looking for thresdhold
Ricoh sense toner in the following methods:
Toner Near End
To detect the toner near-end, the machine uses:
Pixel count (memory chip on the AIO)
AIO rotation distance (memory chip on the AIO)
Toner End
To detect toner end the machine uses:
Output from the TM sensor (center)
After near-end, it is estimated that 200 pages (A4, 5% coverage) can be printed until toner
end occurs.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Apr 01, 2011
My Ricoh Aficio SP C420DN Laser Printer shows color tone SC366 and some time SC365, any ideas?
You just have a problem with colour PCU (SC 365 - magenta, SC366 - cyan). The main reason is that toner density is abnormal. Sometimes, when you replace toners, printer receive to much toner for a short time, and after that you have an abnormal toner density (higher). You can check in service mode (hold up and down arrows for 6-7 sec, release them and press ok button) following thing :
choose 2. engine
then with arrows choose 3. process
then choose Vt display,
for each color by default there should by somewhere arround 2.4V. If you see for some colors, for example 0.02V, then this is a problem(to much toner). In this case the only thing that you can do is to restart printer and try to print enough pages, filled with problem color. Usually you can print max 3 pages. Then restart printer and try another 3 pages. Print until the you will be able to print at least 4 pages continuously.
Good luck and remember that this is a technical problem and you should ask someone qualified for the job. I am sure that 80% of service engineers can't repair this issue. But I can.
Apr 17, 2015 | Ricoh Aficio SP C420DN Laser Printer
Web Replacement error in ricoh mp 9001.
Clear modes(yellow) 1 0 7 hold clear/stop for 5 seconds, and reset the web counter. -Carl
Mar 06, 2015 | Ricoh Aficio Office Equipment & Supplies
What could be the problem on ricoh printer sp c420dn its given me error code sc 364
Probably you have just replace some of the toners (black). The toner density is too high. Restart printer and try to print full A4 black page.
Aug 30, 2014 | Ricoh Aficio SP C420DN Laser Printer
I need to reset the NVram to clear the digital page counter what is the fix
Which model and brand u're using. if you used Ricoh machine and the series of model Aficio that hs possible to reset ur digital counter.
1- put out the NVRAM.
2- rotate the direction
3-turn the on machine for ( 5sec)
4-Turn off machine.
5- put again nvram
6- fix on default direction.
7- turn on machine
and see the counter. after done this work going sp mode and used memory all clear.
Best Regards
Syed Babar Ali
Cell : +971556272142
Sep 07, 2011 | Ricoh Aficio MP 2000 Black and White...
I replaced maintenance kit a and b on a Ricoh sp 8200dn, but it still tells me to change the maintenance kit on the screen. Is there an SP Mode to clear this. I tried SP5507/10 to 1 and SP 5507/11...
Off hand I'm not certain what maintnance kit is type B but you can try resetting the PM counter at SP7804
001 - Is for Paper
002 - Is for PCD (Drum / Dev unit) except developer
003 - Is developer
004 - Is Fusing
005 - Is Web
006 - All Clear
Aug 31, 2011 | Ricoh Type SP 8200 B Maintenance Kit...
Apr 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
Dec 30, 2009 | Ricoh Aficio SP C410DN Laser Printer
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Sep 23, 2008 | Ricoh Aficio 1085 Laser Printer
Error SC940
SC940 - Main Switch Abnormal (U.S.A. version only)
Definition: [level: A]
The Main switch does not turn off after sending the reset signal two times
in a row.
Possible causes:
· Main switch
· Main PCB
You must enter em SP mode and then turn off the main switch and on again.
Entering in SP mode:
Enter SP mode as follows:
1) Press the clear modes key.
2) Enter "107".
3) Press the clear/stop key for more than 3 seconds
Then turn of the machine, don't play around in the SP mode u can damage the Ricoh
Nov 05, 2007 | Ricoh Aficio 450 Copier
313 people viewed this question
jasbo
jasbo
