Question about Kenmore 22422 Top Load Washer
Won't go into Spin mode
I think it was out of balance with a heavy laod when it went into a spin and now it won't drain or spin. When I pull the dial to start it with the door closed or open it makes the sound of the motor working but won't spin. Is there a 'reset button'?. I have looked but not seen one. It is a Kenmore Series 70 top load model # 20712 990. The only Kenmore on the FixYa drop-down menu that was close to mine was the 22422 so I selected that.
Thanks for your help.
    Novelist:
    Champion:
  • 261 Answers
That is perfect, hey does it agitate but won't spin? If it hums and you get no action I would suspect a motor. The best case is a jammed pump, the rest is spendy on parts here is a source for you.
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11022422100&productCategoryId=0153200&brandId=0582&modelName=AUTOMATIC WASHER, COMPACT A/W&diagramPageId=00005&componentDescription=BRAKE/CLUTCH/GEARCASE/MOTOR/PUMP&documentId=P0102319&backToLink=Return to Sub Components list
Posted on Nov 01, 2008
Model 110.28922791. Why doesn't it drain and spin after wash cycle complete?
It went out of balance spin you dial to where spin cycle starts not fill an spin just spin and push in to start the spin again
Hope this helps Mike
Jan 30, 2016 | Kenmore Washing Machines
Mvwx600xw0 wont drain and spin
The out of balance is why it does not spin. You can manually stop the machine, and spin the basket. Then move the clothes until it is balanced. Then start it again on rinse & spin or drain & spin as appropriate. When you get tired of this, try below.
Or you can change the "Soil Level" to heavy or very heavy". This increases the water level and helps it balance the load.
Dec 28, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Washer will not spin
There is a safety switch on the lid ... when it went out of balance perhaps the adjustment changed or it got damaged (loose wire etc.) BE SURE TO PULL THE PLUG BEFORE ATTEMPTING ANY REPAIRS
Oct 02, 2009 | Washing Machines
Maytag washer won't drain or spin Tried breaker already
Your washing machine is of balances and is shutting it down every time it spin
Aug 26, 2009 | Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Kenmore 22422 Top Load Washer Logo
168 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
