Question about Yamaha RX-V463 Receiver
Optical audio i cant get the optical audio inputs to work i have panasonic tv and dvdr connected but both optical inputs dont work...with the dvdr i have used the hdmi i/p and it works in bitstream mode so on the tv i have ste it up to dolby digital o/p in bitstream mode and nothing...ive even conected the dvdr optical o/p to the rcv and still nothing..the receiver is set to auto decoding and auto detect the i/p tv th46pz800a panasonic dvdr is dmr-ex77 panasonic amp yamaha rx-v463 is there somewhere in the rcvr menu to turn on the optical i/p my email is if you can help it would be appreciated
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: I have a Yamaha Rx-v363
you only have to thange the setting for hdmi from stereo to surround
Posted on Jan 02, 2009
  • 4 Answers
SOURCE: tv speaker noise from yamaha rx-v663 hdmi connection
try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Posted on Feb 23, 2009
  • 31 Answers
SOURCE: 8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Posted on May 05, 2009
  • 11 Answers
SOURCE: how to use sap with a rx-v463?
the trick is, it has NOTHING to do with your receiver, and EVERYTHING to do with your TV, you need to choose SAP on the TV not the stereo. That will send the SAP sound to the stereo you are playing the sound through.
Posted on Oct 10, 2009
How do I connect a Panasonic TX-50A300B (TV) to a Panasonic SC-HTB20 Home Audio System?
The audio system sports both a HDMI input AND an Optical input - one can use either. The TV has both of those as outputs so you truly can use either!
You'll need a HDMI to HDMI cable or an Optical to optical TOSlink cable.
Feb 16, 2015 | Panasonic Audio Players & Recorders
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
Jan 01, 2015 | Marantz Audio Players & Recorders
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Cant get hd sound through home theatre system
Hi,here is my simple solution...
to listen your TV on your
Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 26, 2011 | Panasonic Home Theater System System
I have a panasonic TX P50 C3B 50" Plasma TV and want to connect it to a SC PT470 home cinema system only I cant see that I have a fiber optic connection on the tv and no matter what i try i cant get...
If you want to listen your TV on your Stereo system thru your Home Cinema receiver, you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV to "AUX input " or "Any input" of your receiver ( except Phone ) or "Optic Cable input" than just switch to respective mode corresponding your RCA or Optic connection...
There you go..Your TV sound is on the Receiver..
Take care and pls remember to rate me..If you cant succeed you can contact me for more solution..
Jun 19, 2011 | Audio Players & Recorders
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Apr 26, 2011 | Panasonic SCBTT350 Theater System
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Panasonic SA-HE9 amp / Sky+ optical
i Have a Panasonic SA-HE9 and i cant get the optical cable too work on my Playstation 3 to get sound from there. can any 1 help me with this?????
Feb 19, 2009 | Panasonic SA-HE90 Receiver
I have a Panasonic TH-42PZ700A High Def TV and a Panasonic 160gig DVD Recorder. They both have 1 optical audio output each. I have an Onkyo amp which has 1 optical input for audio. How can I have 5.1 dolby...
Dear ritchiewayne,
Please connect optical out of the DVD recorder to the input of panasonic TV. Next connect TV's optical out to the input of Onkyo amplifier. connect speakers to the out put of Onkyo amplifier.
Jun 15, 2008 | Panasonic Televison & Video
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
Yamaha RX-V463 Receiver Logo
59 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
