Question about Sanyo Cinematic Progressive Scan DVD Recorder
Sanyo cinema progressive
Dvd play wont cutoff, play light remain on-but there is no cd in the player will not eject lens has been clean. left unplug overnight- appear to work find via remote and manually. while the dvd player is cutoff mode-it will turn itself on and all the lights remain on as if the dvd player is playing as movie. nope, i dont believe in ghost either.
  • Anonymous Sep 16, 2008
    Same problem. Disc was stuck, took it apart and there is a slider underneath the dvd apparatus if you bring it to the side the disc will eject.
    Sliding peice is a thin plastic peice, about 2-3 inches long faced towards the bottom of the DVD player. This doesn't fix the problem, but at least I got the disc out safely.
SOURCE:
snakehead
  • 1074 Answers
SOURCE: screen displays "no play"
the dvd is having a problem with the lens clean it ,if that does not work take it to a tech to adjust the lens or replace them there is also a flat strip that leads from the lens body to the circuit board this should be change.good luck.
Posted on Apr 04, 2007
hmerchant110
  • 7191 Answers
SOURCE: need manual for Sanyo DVD player, DVW 7100 Cinema
You can download the required manual from:
http://www.retrevo.com/support/Sanyo-DVW-7100-DVD-Players-manual/id/311ag904/t/2/
On the page which opens, click on the GET MANUAL button and follow the instructions on the next page to download the manual.
Hope this solves your problem. Thanks.
Posted on Oct 06, 2009
SOURCE: I lost my remote to my sanyo dvd player (sanyo
remote control now purchase in the market. give the model to salesman compare the model if it same. If no available try the universal remote control.
Posted on Nov 23, 2009
tthekraut
  • 374 Answers
SOURCE: i have a sanyo cinema progressive dvd
what kind of universal remote do you have???? it can vary sometimes from remote to remote
also, do you have the model of the sanyo system??? some models they make are made by other companies so you would have to use their code.
Posted on Aug 04, 2010
SOURCE: there is no sound coming from my sanyo cinema
check the speaker connections and the rca cords
Posted on Sep 22, 2011
I have a Sanyo Cinema Progressive DVD player and the videos are playing back in black and white, rather than in color. What is the problem?
The output signal maybe set to S-video and the input connector does not have S-video capability. Change the output signal or use a HDMI cable. If the connection is via progressive cable (three leads), the colors maybe mismatched.
Apr 09, 2011 | Sanyo Cinematic Progressive Scan DVD...
I have a sanyo cinema progressive dvd player....lost the remote and am trying to program universal...what remote code should I use?
Aug 04, 2010 | Sanyo Cinematic Progressive Scan DVD...
I have a sanyo sx20 dvd player it loads the disc then ejects it just wont load and player can u tell me wot the problem is please
it can't read the disk. clean the lens with a dvd/cd lens cleaner (walmart, radio shack, etc.). if you are technically inclined, you can remove the top, remove the transport top, and clean the lens with a soft lint-free cloth (or a q-tip) and rubbing alcohol. wipe the lens off gently and blow it dry. the alcohol will evaporate. put it together and try again. if it still doesn't work, you'll have to replace the entire optical pickup.
Jan 06, 2010 | Sanyo Televison & Video
Need manual for Sanyo DVD player, DVW 7100 Cinema Progressive.
Oct 06, 2009 | Sanyo DVW-7100A DVD Player/VCR
Dvd will not eject when using eject button.
I am going to sandbag it. I can use that particular cd to workout with. I will just attach a dvd player separate since most postings can't use the dvd anyway after they get the cd out. Thanks for the help anyway! Susan
May 27, 2009 | Mintek LCD TV Progressive Scan DVD Player
Locked dvd tray.
Press and Hold EJECT Button, While UNLOCK Is Displayed :-)
Nov 12, 2007 | Sanyo DVD-7201 DVD Player
Cannot remove progressive scan mode
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
Screen displays "no play"
Apr 04, 2007 | Sanyo Cinematic Progressive Scan DVD...
Plays cds but wont read dvds
upgrade the firmware on the product.
Nov 10, 2006 | Sanyo DRW-1000 DVD Recorder/VCR
Televison & Video Logo
437 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
