SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
SOURCE: ricoh aficio 1035 sc code sc 329 troubleshooting
Laser diode beam not positioned correctly. Turn the machine off and back on and see if it goes away. You can run sp 2109-3 or 2109-4 in the service mode to adjust the beam in service mode by pressing on the yellow button. pressing the 107 keys and holding down on the clear button.
If this doesn't resolve the issue, you probably need a laser which we have one for sale here.
SOURCE: sc 481 on my ricoh aficio 1224
The problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
SOURCE: RICOH 2015 error code sc 500
sc 500 is main motor lock.it happens bcoz of mainly 2 reasons .first main motor faulty.second main motor is not able to take the load tat means cam gear is jammed or broken.
SOURCE: Ricoh Aficio 1232 c SC-101 and SC-142 codes what do they mean?
It is a scanner problem....could be lamp, lens defect, or as simple as the lamp, and lirrors undeer the glass being very dirty, because the code refers to the 'white level"....a calibration that the machine does when switched on. It could be as simple as, the white plate which is underneath the left scale (beside the main contact glass) is dirty (or missing). Try cleaning this (2 screws), and while you're at it, try removing the main contact glass (3 more screws)and cleaning it as well as the scanner bulb, and mirrors (slide scanner to the right with the machine unplugged).
Good Luck
