Question about Kenmore Refrigerators
Kenmore elite 106.74209400
Food in refrigerator freezing
3 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: My refrigerator freezes my food solid
Replace cold control
Posted on May 03, 2009
rylee_smith
  • 8619 Answers
SOURCE: Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2009
Why is my kenmore elite bottom freezer not freezing?
Not knowing how old the unit is, may be a problem to answer.
You may have a fan out or it may need a good defrost.
Remove and items from the freezer and fresh food section and alow to sit un pluged from power for 24 hours. ( Doors open )
May 27, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Food freezing in refrigerator
There has to be a balance between the freezer and the refrigerator because the refrigerator gets its cooling from the freezer, if you set the freezer to cold, the other side freezes,
Feb 17, 2014 | Kenmore Refrigerators
Food is freezing in refrigerator. Settings are single digits (1,2,3). What is average setting for freezer and refrigerator.
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 16, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cannot regulate the temperature and food and vegitables are starting to freeze.
heatman101
Jul 08, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I have a kenmore elite compact refrigerator model 5649149910 and everything inside is freezing on the lowest setting
heatman101
May 07, 2011 | Kenmore Refrigerators
Kenmore Elite refrigerator model # 106.74206400: freezer compartment working fine, refrigerator compartment about 20 degrees too cold. Found a method for running a diagnostic: 1 and 2 passed, 5 failed. ...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 12, 2011 | Refrigerators
Have a kenmore elite bottom freezer that is not
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 08, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite refrigerator. both compartments (bottom freezer and top refrigerator)are not keeping with the temperature setting. the food is cool but not cold as it should be. how can I test to see if...
Really most folks have to keep their setting on their fridge on about a 6-7 or-8 setting with the amount of food that is kept in the fridge now.
YOU CAN KEEP AN EYE ON THE RELATIVE temp if you like by placing a fridge thermometer in the appliance. Optimal fresh food should be around 40-43 degrees F on average to keep things on the cooler side without freezing.
Hope this helps
Nov 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
