Which wires do i connect for my Sentrek SEQ 740
No color code
Need a wiring diagram for a sentrek 2channel amp. model spa 120
You might be able to get a diagram from Sentrek.
Jun 03, 2014 | Pool & Spa
I cant get a stereo hooked up
Your question is not very specific but I expect that you have discovered that Volvo does not bother to color code their sound system wiring. They seem to use whatever wire they have laying around, so there is no particular pattern, and often all the wires are the same color.
If your car still has the original stereo plugs, you can buy a wiring kit from the installation shop at Best Buy. It will have a plug that plugs into the Volvo plug and wires that are color coded to standard color coding so you can figure out how to connect it to the new stereo. I not only had to put in a new stereo, but I had to bypass the original amplifier in my '91. The kit from Best Buy made it all Plug and Play!
Jan 22, 2011 | 1989 Volvo 740
We can't get typewriter to stop beeping once it is turned on. Is there a code? model 3 AE-740
No code that I know of, however there are wires that break in the print harness just about 1" from th L. frame.
DickyO
Aug 03, 2010 | Nakajima AE-740 Typewriter
Cannot print.
ITs communication problem, check the cable, and check the driver could be corrupted, reinstall the driver to make sure, and try different cable to connect.
Apr 22, 2009 | Epson Stylus Color 740 InkJet Printer
CanoScan FB330P
commen fait t'on pour le faire marcher sur l'ordinateur s'il est installer
Apr 08, 2008 | Canon CanoScan FB630P Flatbed Scanner
Sentrek car amplifier
The remote turn-on wire for an amplifier connects to a switched power source. If the head unit has a power antenna lead, or amp control lead, use it. If not, the remote lead can go to a power source that is switched with the ignition key. No matter the source, you need to fuse the wire with a 1 amp fuse at the point where you connect to the power source.
Oct 22, 2007 | Car Audio & Video
Epson 740 Printer
This is an Epson 740 driver for Macs: --> http://www.download.com/Epson-Stylus-Color-740-Printer-Driver/3000-2296_4-901012.html
Aug 04, 2007 | Epson Stylus Color 740 InkJet Printer
29 people viewed this question
k24674
