Question about Acer Aspire T160 (AST160UA3400) PC Desktop
Turns on but no boot
My computer turns on with the fans at maximum speed and stays at max speed
usually they go to normal speed after a few seconds when my computer turns on
the hard drive turns on
but nothing happens
it just sits there running at max speed
nothing appears on the screen except it says "no input signal" but its plugged into the computer, but the monitor i think is not the issue
it just wont start up
thanx
  • Glen Davis
    Glen Davis May 11, 2010
    does it beep?
I had this happen sometimes after a windows update/reboot.
If the computer is on, hold down the power button until it cuts off.
Unplug the power cord. Wait for a couple of minutes.
Plug the cord back in, and turn on system.
Posted on Feb 12, 2010
Why doesn't my fan rotate anymore?
definitely sounds mechanical. try prying open the motor area and see if anything happens when you turn it on. i'm guessing it might be a short somewhere that's making the other parts have to compensate
also check into servos, relays, and whatnot
May 15, 2015 | Miscellaneous
Gateway GT5622 PC Desktop won't boot
It could be a problem with the vcard, mobo or the psu
Jun 09, 2014 | Gateway GT5622 PC Desktop
My daugher has a 2008 prius, had a flat tire and now has the spare tire on. What is the maximum distance and speed she should drive
I do not know the maximum distance, but there should be a wear indicator on the tire. Usually the max speed on doughnut tires is around 50 mph but the owners manual will clarify. Usually the spare will have a max speed posted on it somewhere with a sticker.
Please let me know if I can further assist you.
Mar 28, 2011 | 2008 Toyota Prius
I have a Jazzy Select model. Fairly new. It
It could be that the acceleration is set to low. This setting adjusts the time it takes for the chair to reach maximum speed that you have selected on the joystick. With a low setting, it takes it a few seconds to get to maximum. Reprogramming the acceleration to a higher setting decreases the amount of time for the chair to hit max speed. You will need a PP1 handheld programmer from P&G drives technology to change the settings, or take it to a local DME specialist who will usually have a programmer to reset the joystick.
Oct 28, 2009 | Select Jazzy Used Electric Wheelchair
The server is very loud all 3 fans come up at full speed
hello.
lets check DSA log from your server (use DSA Bootable Edition and post resulted file *.xml.gz).
Also check the next doc:
Improper installation of fan cage may cause fan errors - System x
www-304.ibm.com/jct01004c/systems/support/supportsite.wss/docdisplay?lndocid=MIGR-66880&brandind=5000008
Jun 20, 2009 | IBM x3400 Server
I cant get the fans to turn on!!!!!!!!!!!
Call up the 'Integration Menu" - the fans can be switched between 'auto' and 'full speed'.
To do this switch the display into standby. If the standby light flashes 4 times it is indicating a fault in the Thermal Sensor Assembly which will explain why your fans aren't working. With the display in standby press the menu button and within 3 seconds press the power button. The display will turn on with the integration menu. Select the option tab and scroll down until you see 'fan control' - press 'set' to toggle between 'auto' and 'max'. When you select 'max' the fans will run at full speed within a few seconds. The fans are a bit noisey at full speed so you may want to look into replacing the sensor eventually.
Feb 19, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Computer goes on but does not boot
When you start up the PC, do you get any kind of beep sound? If not, I would reckon the RAM modules are faulty and would need to be replaced first. That is the usual cause for this kind of issue. Also when replacing the modules, make sure they are the type supported by your motherboard, ie DDR, DDR2, etc. You will have to consult your m/b manual for this..
If the problem is not with the RAM, ie you hear a beep, but nothing else, I would guess that the MBR of your operating system is dysfunctional, which would mean that you would have to reinstall the operating system.
Hope that helps...
Cheers!
ID
Oct 28, 2008 | Acer Aspire T160 (AST160UA3400) PC Desktop
Tower computer
that could only be your cooling fan. initial speed at maximum then turns to lower speeds when system has done POST.
Apr 11, 2008 | Computers & Internet
Acer Aspire T160 (AST160UA3400) PC Desktop Logo
230 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
