FixYa.com
Tags:
Brother HL-2040 Laser Printer
Out of paper light (by 4 users)
posted by oceanic on Aug 29, 2006
hi
my paper light is flashing red and when i go to print my dialogue box says that i'm out of paper.. but i'm not. it won't let me print.
also when i send a print job to my printer sometimes it registers but more often than not it will not even register the print job in its job dialogue box.
any ideas?
printer: hl 2040 brother laser
thanks
ora
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by bandb, posted on May 14, 2008
Brother HL 2040 black and white laser - "paper" light is flashing red yet plenty of paper in the drawer. It won't print!
Comment by lenco, posted on Jan 05, 2008
red light keeps flashing
Comment by LCOPPOLA, posted on Nov 01, 2007
My 'out of paper light' keeps blinking although I have paper installed. I unplugged it and re-plugged it back with no success. I reduced the amount of paper in the try and still no luck. Removed the cartridge and re-inserted it with the same results. Any ideas??
Best Solution
posted on Nov 11, 2007
FixYa! (100)
Dimister
Rank:Apprentice Apprentice
Rating: 96%, 8 votes
I've been stuck with a flashing red paper light for a while. The printer could print from the manual tray and could also print test or diagnostic pages.
So I thought it might be driver related, and indeed it was.
There's a nasty setting in the printer properties that makes the printer go woo-hoo. So go to printer properties > tray settings. Check the "paper size" of "Tray 1". If it's set to "undefined", change it to your corresponding paper format. Click Update, Apply. Now print happily.
I still wonder why that setting magically changed. Hope this helps someone.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 17, 2007
FixYa! (100)
majjicboy
Rating: 95%, 6 votes
I tried all the above ( except #2) Nothing worked.
Very frustrating!!! As a last effort I opened the back and noticed
a paper jammed. Pulled it out. BINGO!!! The red flashing
light went away and the green light started flashing.
It finally printed.
ps. I also changed the tray settings as above
Solution #3
posted on Nov 05, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
throw it out of the window
Solution #4
posted on May 29, 2007
Thanks for Trying (70)
Terri Adams
Rating: 71%, 30 votes
Try turning it off and restarting it. Make sure there are no hidden papers in the back or stuck in the toner cartridge before you do this.
Solution #5
posted on May 15, 2007
Guest
Guest
Rating: 0%, 0 votes
Hold down the blue GO button, then the lights will light in a sequence, and than it will reset itself.
Solution #6
posted on Mar 31, 2007
clazza
Rating: 65%, 26 votes
Just hit the blue go button.I have to wait until it stops whurring before I send another task
Solution #7
posted on Jul 27, 2007
Guest
Guest
Rating: 0%, 0 votes
Reduce the amount of paper in the tray. It just worked for me.
Solution #8
posted on Mar 05, 2008
Not Rated (0)
lkvishwa
Rank:Wiz Wiz
Rating: 82%, 33 votes
The problem is of your paper sensor, if possible check your paper sensor. Clean the sensor or reconnect the paper sensor, your problem may be solve.
Can you Help with these Printers problems?
Beother Hl 2040 printer
The drum light was blinking so... Answer This...
line on left side
My printer leaves a straight... Answer This...
All LEDs are flashing
The Toner, Drum & Paper and... Answer This...
Yellow Toner Light Flashes -...
Toner light just started... Answer This...
Red light is always on
Please give a solution for the... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
