Question about Boating
1997 25hp mercury outboard wont charge all the time
SOURCE: mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
Posted on May 29, 2009
  • 677 Answers
SOURCE: Mariner 25hp 2stroke outboard. runs fine when
With what you said.get the water pump done.A little bit of rubber is cheaper than metal.If the motor has a few years on it,the pump does need to be replaced.If the motor overheated after a few minutes,the pump needs replacing now.Yours sounds like it's on it's way out.A bit of sand etc. can do a fair bit.Hope this helps
Posted on Sep 10, 2009
  • 56 Answers
SOURCE: i have a 25hp seahorse outboard 1974 and is misfiring and
Fuel Filter???
Posted on Sep 16, 2009
jdlipscomb41
  • 157 Answers
SOURCE: 1997 Electric start 25HP Susiki outboard
its called a neutral safty switch
Posted on Sep 19, 2009
  • 1168 Answers
SOURCE: I have a 1970's 25hp Johnson outboard motor. Last
Hello Adam.
If your propeller is OK, your lower unit will need some repair. It may be as simple as a clutch dog worn and not engaging the gear. Usually they give warnings of problems by jumping out of gear though.
Other possibilities are broken driveshaft, propshaft, or gears. If it goes into reverse the shafts are OK and the clutch and forward gear become suspect.
It was common for these engines to break at the top of the driveshaft where they were tapered.This would give you no motion at all and no previous warning of a problem.
Check the gear lube for metal particles and signs of water intrusion. I hope your repair is an easy one.
KL
Posted on Dec 08, 2009
50hp Mercury outboard electrical schematic
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Jun 07, 2017 | Mercury Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
What year is my mercury outboard searial no 3768233
Check here, you'll need the horsepower and lookup the serial-number range...
http://www.iboats.com/basics/serial_number_year.html#mercury
Aug 31, 2014 | Mercury Impeller, Water Pump - for...
9.9 mercury outboard timing
timing is not adjustable on small outboards. it is fixed by the flywheel key
Aug 09, 2014 | Light Outboard Motor Boat Bass Fishing...
We have a mercury 60 2stroke outboard engine and nothing happens when you turn the key to start it
go through the basics first: is the kill switch on, battery switch on, battery charged, are the battery cables clean? if not these then most likely the starter solenoid or the key switch itself
May 09, 2010 | Raymarine St6002 Smartpilot Hydraulic...
1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
Sep 03, 2009 | Boating
Mercury outboard over charging
May 09, 2009 | Light Outboard Motor Boat Bass Fishing...
Changed the ignition switch on 150 EFI mercury Outboard
just take the old one off and put the new one on just like you took the old one off
May 05, 2009 | Raymarine St6002 Smartpilot Hydraulic...
Boating Logo
107 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
