Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
My francis Francis X1 constantly drips water from the steam wand. i've decalcified and decalcified. Any help??
Its when its heating up and especially when its brewing. I can;t get the knob any tighter.
  • FrancisFrancis! Master
  • 1,711 Answers
The problem is with the two O ring which are on the steam knob srew. So you need to disasemble the steam knob srew by turning it all the way reverse. On the srew axis you will find two O rings which must replace. You can fint easy replacements O ring from DIY shop they usuly have O ring kits with diferent sizes so take one with youto match it with that of the shop.
Posted on Feb 25, 2012
Testimonial: "just wanted to follow up on this... i unscrewed the steam knob screw, and indeed, it was the problem. the o rings were fine, but the metal collar they were near was completely defective and torn up. i ordered a new steam knob screw from illy and voila!! my machine works like a charm!!! thanks!"
  • apfoff Feb 27, 2012
    Thank you so much! i'll try this solution and post the results. Thanks again!
SOURCE: Steam Wand Broken
I soak the steamer tip in flat cola overnight to clean out milk deposits. Run water, not steam through it after that to rinse.
Sometimes I need to use a toothpick to lift off the softened deposits.
Posted on Feb 27, 2008
jmgldsmth
  • 1869 Answers
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
  • 1089 Answers
SOURCE: drip drawer for white FF X1
HI
Try Illy.com
877-469-4559
They should be able to point you in the right direction
Posted on Nov 24, 2009
  • 1089 Answers
SOURCE: francis francis X1---the steam nozzles won't work,
HI Unscrew the chrome tip from the wand. Then check the wand tube for a plug. Insert a paper clip into the wand tip to see if there is a restriction.
Posted on Feb 07, 2010
  • 11 Answers
SOURCE: Francis!Francis! X5 leaking water from steam wand
Try descaling it.
Posted on Jan 30, 2011
I have a Francis Francis x1 machine, but when i want to make an espresso shot, and turns on the espresso button, the steamer spour out boiling water (not steam, and not while turned on). Does anyone k
Don't know how your controls are set, but you have two switches on the front and a knob on the right. The switch for the steamer (the right hand switch) should be off. The knob on the right should be turned clockwise to turn in off. Then no water or steam should come out of the steamer wand. If it does, the seal on the knob inside the machine is broken. It can be repaired but only if you're handy with a screwdriver (make sure if you take it apart you disconnect it from the mains).
Jun 24, 2014 | FrancisFrancis! Coffee Makers & Espresso...
Lost nozzle on steam wand of Francis Francis x7
I did a quick search, and unfortunately, your only realistic options are to either fabricate yourself one, or try to get one via the manufacturer.
Sep 02, 2012 | Illy Francis Francis X7.1 iperEspresso...
Have purchased the Francis Francis X1 iperEspresso Machine and love it. Unfortunately the steam wand keeps blowing the plastic end part off into the milk during the steam function. There seem to be 2...
I for some reason lost the chat session, at my end with you earlier, this is mr bean. Did I help you to the point of checking out local restaurant. Supply stores or espresso appliance repair shops in your area? I wrote you earlier back, and don't know if you got my message of taking it in local to have them put on the new wand, with the new o ring. I feel you could do it yourself, you might be able to contact machine manufacture and get that wand from other machine that you want to put on yours and ship it to you, and try put on yourself or local appliance repair/espresso machine shop to instal it, take maybe10 minutes ton change over. Again sorry if last message i sent you didn't get or this is a rerun. Fun life if computers lol . Please let me know if I have helped, thanks mike (mr bean)
Jun 09, 2011 | Coffee Makers & Espresso Machines
Francis francis X1---the steam nozzles won't work,
Feb 07, 2010 | FrancisFrancis! Coffee Makers & Espresso...
May 21, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis francis milk steamer not operating
Check the end/nozzle of the steam wand, if you open the wand and while getting nothing it is hot, then the nozzle is blocked use a paperclip to clear the hole at the end of tip. If you have done this already and still no steam then it is clogged where the steam valve connects to the boiler.
May 19, 2009 | FrancisFrancis! X1 - Stainless Steel...
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Francis francis x1, blocked steamer
Pour in a solution of 50% distilled white vinegar and 50 % water. Set the steam wand knob to a water setting, and run the solution through there. I would suggest letting a small amount of the vinegar/water solution drip out, then cut the machine off for about 20 minutes - allowing the vinegar to thoroughly soak and decalcify the insides. After 20 minutes, let the remaining vinegar/water pour through.
If the problem persists, Francis Franic is now owned by illy - 1-877-469-4559
-Tha Mp3 doctor
Oct 05, 2008 | FrancisFrancis! X1 Espresso Machine
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
535 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
billconfused
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
