Question about Whirlpool Dryers
Model LER3624EQO Heavy duty, extra large capacity Serial No. MHO367808 Type No. 122-00
futureloginn
  • 734 Answers
SOURCE: dryer won't start due to delay button lights up and won't go off
1. No power to the dryerMake sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Posted on Dec 02, 2008
futureloginn
  • 734 Answers
SOURCE: dryer not heating
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
  • 78 Answers
SOURCE: my gas dryer spins but doesent get warm at all
When you turn it on listen for a clicking sound. If you don't here that. The electric igniter needs replaced. And sometimes theres a circitboard that goes bad. But its gas, and there fore very dangeruse. FOR YOUR SAFETY IF YOUR NOT EXPERANCED WITH GAS APP. GET A PRO TO WORK ON IT.
Posted on Jan 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Posted on Feb 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
I have a Gibson heavy duty - extra large capacity washer that I need a belt number for. Model number is GWX433RHS1 and serial number is XC12101302
Belt # is 134511600 and is available at most parts stores. If you need to order on line try https://www.vvapplianceparts.com/. Cost is about $15.
Jul 12, 2015 | Washing Machines
Hello, my Frigidaire heavy duty-extra large capacity-2 speed combination-3/4 hp motor washing machine has sprung a leak internally on the left side. How do I remove the front cover panel to troublesho
The easiest way to help you is to recommend you go to YouTube. type in Frigidaire washing machine disassembly. Repair Clinic has been the most useful for me. http://youtu.be/qcViH3Samp8 Good Luck.
Dec 21, 2014 | Frigidaire Washing Machines
Old ge heavy duty extra large capacity washer g157
You have the wrong category, post question to Washing Machines Category. A bit more info would help, like what the problem is.
Jul 04, 2013 | Computers & Internet
Model number AS 200 serial # 251033 Maytage
either a bad pump or a worn or missing belt, lean machine back and check your belts
Sep 19, 2009 | Maytag Washing Machines
3.6cu ft.
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
Year of dryer
INSIDE THE DRYER DOOR IS WHERE MOST MODEL NUMBER ARE OR ON THE TOP BACK OF THE DRYER HEAD,THANKS
Jul 23, 2008 | GE Dryers
Help with my washer
The lid switch is probably broken does it just sit there at the first spin cycle??? Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!
Sep 30, 2007 | Washing Machines
Dryers Logo
127 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
