Question about Canon Pixma MG5220 InkJet Printer
Canon mg5220 printer network connection problems
Can't detect printer thought it is connected to network
SOURCE: Canon LBP 2900 printer problem.
i canot download the driver of canon lbp 2900 printer, what will do?
Posted on Jan 15, 2009
SOURCE: Canon MF4370dn printer network connection problem
I had the same problem. I entered the info manually and it works. You could follow the instructions on how to do it manually in the e-manual (on the CD).
To get the IP, subnet mask, and default gateway: open a command prompt from windows. At the command prompt, type "ipconfig" without the quotes. Write down the IP address, subnet mask, and default gateway.
For the IP, for example, if what you have from the step above is 192.168.0.100, add 10 (so that you wont have repeated IPs by auto DHCP from the router. I am assuming you have no more than 5 machines on your network.) to the last number to have 192.168.0.110 to enter manually into the printer. Use the same subnet mask and default gateway.
Hope it helps.
Linh.
Posted on Jun 02, 2009
  • 89 Answers
SOURCE: connected ir3300 to network. Can ping static ip
Did you just install a NIC (aka ethernet port) in your copier?
To print Network Multi PDL Printer Kit C1 needs to be installed. This contains the NIC and the N Boot-Rom. The copier then needs to be upgraded with networked firmware using SST.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Check the number for BOOT-ROM. This should have a N at the end. If not you need to replace the C BOOT-ROM with a N BOOT-ROM.
Also under Copier > Display > Version check the number for PS/PCL. If this is blank then you don't have printer drivers installed on the copier. You will need to get a technician to come out and upgrade the firmware on the machine.
Posted on Aug 18, 2009
allanhunt
  • 135 Answers
SOURCE: printer is offline
check printer server
Posted on Apr 04, 2010
  • 352 Answers
SOURCE: My Canon mg5250 printer has
Are you running a wireless access point?
If you currently have the printer connected to one computer with no access point in between then it will not find the printer. This type of network is called a Ad-hoc network and is for device to device only, not multiple devices,
For this you need a access point. Regards GM
Posted on Jul 15, 2011
Error code B200 with message reading: Unplug power cord and contact service centre
VH monitor error
mainboard or printhead error
only replace can fix problem
Jan 07, 2016 | Canon Pixma MG5220 InkJet Printer
Printer is ccted to wifi. so is laptop. when I go to print it just says getting printer information. how do I connect
Unplug and shut off all devices, restart and see if connection is made. Was the driver disc installed in laptop for this printer? Might have to create a new wifi network if communications are not being made.
May 07, 2015 | Canon Pixma MG5220 InkJet Printer
Hello, i need a service manual for my canon pixma mg5220. thx
hi, you can download the service manual for canon mg5220 from the below link:
http://goo.gl/VNIW8E
good luck
Sep 11, 2013 | Canon Pixma MG5220 InkJet Printer
Unable to find printer on wireless network
update drivers, through manufactuares web site,
Sep 04, 2012 | Canon Pixma MG5220 InkJet Printer
Every time I try to print my canon pixma MG5220 says 'printer error 6C10'
You need replace the ink absorber .
Or you can disassembly the printer and clean with running water tha ink abserber.
Is located below the cartrigde
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 27, 2011 | Canon Pixma MG5220 InkJet Printer
My Canon mg5250 printer has been set up and has successfully connected to my wireless, however when I set up my laptop with the installation CD and it goes to find the printer it says 'The printer...
Jul 15, 2011 | Canon MG5250 Printer
Printer not responding.---> This is what I'm getting from the printer whenever I try to print and I'm using a wireless, printer model is Canon MG5220. Hope you guys could help me.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 08, 2011 | Office Equipment & Supplies
Canon MP495 Pixma scanner says this when I try to scan something. Cannot comunicate with scanner for these reasons: -Scanner is turned off -Scanner is disconnected (It is disconnected from LAN, if...
Regarding the Cannon scanner error 2145,50. The MG5220 does this also. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it, for me at least.
I know, I had that problem. I am a retired electronics design engineer.
Jun 30, 2011 | Office Equipment & Supplies
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon Pixma MG5220 InkJet Printer Logo
65 people viewed this question
old marine
old marine
