Question about Frigidaire Refrigerators
1950 frigidaire wiring diagrahm
White black green leads to compressor which is start run common
tom19511
  • 1601 Answers
SOURCE: front usb s don't work
need to know :
motherboard model
case name and model
Posted on Nov 18, 2007
rayname
  • 70 Answers
SOURCE: New air compressor motor to 220 vlt?
if you have a 220 v service 1 phase meanig there is 220 volts across your existing two power feeds and your motor only has 3 wires there is usually a low voltage and high voltage schematic on the motor if you are wired as per this then your green is standard ground and black and white are your hot wire or line voltage let me know if you have any other questions
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: I have a Hunter 27185
you can use the red or the blk for blk,wht red
Posted on Mar 31, 2009
  • 127 Answers
SOURCE: REPPLACING FAN AND COMPRESSOR CAPACITORS WITH A SINGLE UNIT
Well, it sounds as if you have a Coleman rooftop unit. If you have a start capacitor with a PTCR (Postive Temperature Coefficient Resistor) then it is different than if you have a Potential Motor Starting Relay. Why are you replacing the run and the fan capacitor?
Here is a link to the documentation that you need. If you do not have a Coleman and it is in fact a Duo-Therm, let me know the model number and I will be able to pull up the wiring schematic.
Thanks,
Jeff
Rate this please!!
Posted on Jul 04, 2009
  • 351 Answers
SOURCE: Wiring instructions are terrible. Ceiling wires =
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
Posted on Jun 04, 2010
Century motor wiring diagram for 8-152863-01 motor
You can\'t run it on 220, but if you take only one of the 220 black wires and attach it to the black on the compressor you are feeding it 110. The problem will be that you have no neutral wire so you\'d have to use the ground of the 220 lead (green) as the neutral on the compressor (white). It\'ll run fine but it\'s not the right way and it can be a hazard. The white wire is neutral which is basically a ground wire from the electric company, the green is the ground wire in your building and it\'s there for safety so using it to power things is dangerous and probably illegal. I\'ve done it in a pinch, but wouldn\'t do it if at all avoidable. You may be able to get a transformer but you\'re probably better off running a 110 circuit or getting a 220 compressor.
Jul 29, 2014 | Sanborn 20 Gallon Horizontal Portable Air...
The compressor is 3HP 230 v motor. In the pressure switch it is wired white and black from motor and green to ground. Is the white and black wire 115 volt each or it the white wire common and black wire...
If the motor is 230 v then it should have three wires, black, red, and green, however if the motor is convertible from 120 to 230v then the wire from the motor may be black, white, and green. Check the motors label to see if it has different wiring configurations. If the motor is 230 v only then the white wire would be the other side of the 230 v circuit, and the pressure switch should break both sides. Neutral is not used. Note that some people would use a single pole pressure switch, although this will work it is not recommended.
May 07, 2011 | Ingersoll Rand Single Stage Electric...
I have a 240v plug in with 4 wires ( red and black-hot, white-common, and copper-ground) and on my campbell hausfeld air compressor i have only three wires ( white and black- hot and green-ground) how do i...
First are you sure your compressor is wired for 220. If so \,use the white and black for the hots connected to the black and red in your recptacle. Connect the green to green or bare conductor. The compressor most likely has no 120V devices on it so the neutral is not requied.
Jul 13, 2010 | Campbell Hausfeld Air Tools & Compressors
Mains wire at back of fridge has come out how do i re-wire it
Hi, are you saying that the main power cord has been pulled loose from all connections? Has any componants come along with it? Wiring a power cord is fairly an easy task if you are familar some what with wire colors for a 120 volt power cord. You should be able to take a good look at where it has come apart and reconnect the cord with wire connectors, as Hot would be black to black, and white is nuetral, so white to white and green for ground to the appliance. Now, If you have accidently pulled out the wiring from the compressor terminals, as the start, run, and common terminal, I need to no this to quide you through this, as there is also a overload relay that is wired through the common terminal to protect the compressor against an overload. Please get back to me if this has happened.
Sincerely,
Shastalaker7
Jan 13, 2010 | Refrigerators
1994 Ford Aerostar radio wiring
FORD up_arrow.gif P o w e r Memory (+12v Constant) Green Yellow Ignition (+12v Switched) Yellow/Black Ground (-) Black or Fat Red Illumination Orange Dimmer Orange/White Power Antenna Blue (varies greatly) S p e a k e r s Right Front (+) White/Green Right Front (-) Green/Orange Left Front (+) Orange/Green Left Front (-) Light Blue Right Rear (+) Pink/Blue Right Rear (-) Green/orange Left Rear (+) Pink/green Left Rear (-) Pink/Blue
Dec 15, 2009 | Car Audio & Video
I just purchased an used furnace model # 4E458 and serial # Q9541564. I am trying to find a wiring diagrahm. Where can I get one? Thank you Joe Biernasz
if you go to the manufacturers web site they should be able to help. but most of the time you just need to hook up your high voltage(120v) which if your black, white and green. and on your low voltage side it is usually red=r,green=g,yellow=y and w=white. if you have a thermostat that is battery operated than you do not need a common wire. if you need a common wire than us the blue wire. and if you are hooking up an a/c system then hook up 1 wire to y and the other to common
Nov 10, 2009 | Dayton Gas Furnace Heater
Jenn Air cooktop has 4 wires Black, white, red, and green and my house supplies power with 3 leads white, black , & green. How are the wires hooked up to power the unit?
Old plug: green is ground, white and blace are both hot power. New cooktop: green is ground, WHITE is COMMON, black and RED are hot power. You are going to need an electrician to run a new circuit and plug for your new cooktop.
Aug 31, 2009 | Jenn-Air JED8230 Electric Cooktop
Compressor problem, installing the Supco 3-in-1 Relay
Hi, If the 3 posts are top center and bottom right left, the black wire goes top the top center post. The red wire will go to the bottom right and the white goes to bottom left.
If the posts are bottom center and top right left, the black goes on bottom center and the red goes top left. The white goes top right.
If you do not see a capacitor, disregaurd the wires in the 3-1
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Tfi module wiring diagrahm
What I got from Ford is not working on mine #1 is bottom wire black orange,white light blue,red light green, red light blue,yellow light green, top is dark blue? I don't have a dark blue wire? I have a white wire?
May 18, 2008 | 1984 Ford F 150
REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Feb 14, 2008 | Dryers
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
