Question about Vacuums
I have a Turbo Steamer 220 and there is no steam coming out of it when I pull the trigger. Do you know how this can be fixed?
It heats up & the pressure builds up inside the unit, but no steam coming out.
SOURCE: Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Posted on Jan 24, 2008
SOURCE: no steam
my steamer heats up but no steam come out. There is also a dial on the nozzle with an arrow, that I can not move. my phone # is 239-333-9844
Thank you! Joanie
Posted on Nov 29, 2008
  • 4088 Answers
SOURCE: Steam doesn't come out anymore when I pull the
Try putting some white vinegar in the tank to dissolve any hard water deposits. You should use only distilled water in this machine. Don't try to clean anything with the vinegar in it, but take it outside to run the vinegar through.
Posted on Aug 15, 2009
  • 143 Answers
SOURCE: Shark steam blaster jr. makes steam but has no pressure
yes no vinegar please. Try a product called scale clean or tablets for de-scaling coffee machines. Available from coffee machine retailers
Posted on Sep 20, 2009
Testimonial: "I'm glad to know there is such a product (scale clean) for descaling coffee makers and my steam cleaner. Thank you!"
SOURCE: the seal on pressure cooker
Require pressure relief valve o ring
Posted on Apr 17, 2011
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
Simac evt 100 steam cleaner
Try taking the steam head apart and cleaning. If difficult to remove, fill a basin with white vinegar & a small amount of water and let it soak to remove the built up deposits in the system. Remember to only use distilled water when steaming to avoid build up.
Mar 30, 2014 | Vacuums
My Shark hand held steam cleaner sc 505 is not building up pressure, steam is leaking from lid
Throw it out, get a hoover floormate, best machine I ever had. My Shark steam/vac now resides at the dump after steam clogging problems and not being able to remove the hose to blow it clear.
Mar 17, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Unit not working to heat water--cant hear compressor starting up like normal
Did you make sure that it was closed all the way? Sometimes if the water canister is not on all the way it can cause this. And depending on how old the steemer is maybe that part went out. But I would check all the lines to make sure nothing is clogged or pinched
Jun 07, 2012 | Vapor Professionals TR6 Canister Steam...
Easy steam express ll not steaming
The problem with the DD steam mop is not getting steam out but trying to get it to keep coming out. If U disassemble the plastic housing around the handle U will see a small part connected to 2 hoses, one going to the water reservoir the other going to the heating unit. This is the pump which provides water to the heating unit, and if this fails U won't get steam. U can try disassembling this and try to get the piston to move more freely. A loud clicking sound coming from this should indicate good movement and a feeble click click click may indicate restricted movement.
Hope this helps
Apr 28, 2012 | Dirt Devil CE7000 Easy Steamer Upright...
The seal on pressure cooker #99700 leaks after pressure builds up and a dangerous amount of steam is expelled . we were almost scaled by the steam.
>>> Please leave feedback so I can continue helping You & Others
make sure the pressure relief valve is working, not blocked etc, if it's OK try replacing the seal.
Thanks,
Adam.
Feb 19, 2011 | Vacuums
My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti vaporetta - steam escaping from valve
Are you sure it is not escaping from the top? if so replace top.I have had this myself
May 11, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Vacuums Logo
254 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
