Question about Zanussi Ovens
Zbp1165x zanussi oven, oven overheated to very high temp while cooking. error f 05 on display
SolutionGuy
  • 331 Answers
SOURCE: Lang Oven EHS-PP
WB, Your thermostat is shot and must be replaced. The most difficult part of this job is locating one to replace it with. Have the complete Model and Serial number handy... First, try locally. Call a local Commercial Kitchen repair/parts house. Surely theres one nearby, they work on all McDonalds, Wendy's, Restaraunts, etc... cooking equipment. Second, contact the manufacturer; Star Manufacturing International, Inc. 10 Sunnen Drive St. Louis, MO 63143-3800 Phone (314) 781-2777 (800) 264-7827 Fax (800) 264-6666 After you have it, SHUT OFF THE POWER AT THE BREAKER!!! Now try to turn the unit on to VERIFY you have no power. Then remove the t'stat knob. Now remove the screws holding the control panel in place. Tilt the control panel out toward you. Now you can see the t'stat and see how the sensor bulb is routed. (HINT: Take a piece of paper and draw the back side of the t'stat's wire connection locations and wire colors/numbers, BEFORE removing anything.) Remove the wires and the t'stat and route/wire the new one the same way. Another tip; Be extremely careful with the sensor bulbs capillary tube (the small tube connecting the bulb to the t'stat). NO 90 DEGREE BENDS ALLOWED! It is a hollow tube, if it's piched/kinked you can throw it in the trash and buy yourself a new one. (It came packaged as a coil for a reason) As you uncoil it, go slow and easy.
Posted on Aug 23, 2007
  • 409 Answers
SOURCE: maytag mgr5870 not baking correctly
hi there,
sounds like the TOD may be at fault. can you supply me with the model # on your stove please?
as far as the popping sound, that would the spark module.
Posted on Sep 14, 2008
localwonder
  • 6784 Answers
SOURCE: F3 & F1 Errors & oven shuts off
Concerning the F3(Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Concerning the F1(Stuck touch pad)
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Posted on Jun 03, 2009
  • 75 Answers
SOURCE: turbochef toaster oven cc temp on warm up only 265 deg ir 465
if your a commerical oven tech then just call 1-800-90turbo are you getting an error code i would probably check the convection circuit first starting with the blower motor and checking if the Windings are ok
Posted on Jan 28, 2010
  • 320 Answers
SOURCE: Zanussi double oven switches off during cooking.
The shutting down of the oven is due to a defective thermal switch or thermistor. Replacing the thermistor could fix the problem. It is usually located in the inside compartment of the oven and connected to the control panel board.
Posted on Dec 02, 2010
My zanussi zpb 1260 oven has stopped working after a pyrolytic clean. I set the oven and the display is correct but after a couple of seconds the the temp goes to 20 and nothing happens, tried switchi
Go to Zanussi . com select UK then manuals you will need more information a serial number and then download it, there should be an answer in there okay.
Regards
John
Nov 02, 2014 | Zanussi Ovens
How to wire up a zanussi zop37902 oven
You will need to have an electrician connect the oven to your power system in your home, unless you are expert at doing this yourself. ZOP37902XK Ovens Zanussi Products Cooking
Jun 07, 2014 | Zanussi Ovens
Zanussi zob550xl built in oven is overheating
it sounds like a temp sensor, or thermostat...both are easy to change.
Apr 20, 2014 | Zanussi ZBF360X Electric Single Oven
Oven is showing f2 what is happening
Hi Nancy:
Error Code F2 indicates a loose or broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced.
Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Hope this helps; thank you for using Fixya. Keep in mind that your feedback is important, leave us some testimonial comment.
Nov 24, 2011 | Magic Chef Ovens
My Zanussi double oven switches off during the cooking period.
If it turns off after it has been on a while, then it could be caused by overheating due to failure of the external cooling fan.
The fan is designed to prevent the oven overheating, and failure of the fan causes a safety thermostat to operate and stops the oven from working.
You need to access the fan to check that it is working.
It is usually located at the top of the oven at the rear, and entails removing the top cover and the back cover possibly depending on the model number.
What you are looking for is a cylindrical type fan about 8" to 12" long, again depending on model.
Hope this helps solve your problem.
If you requies any nore info, please e-mail.
Dec 23, 2010 | Zanussi Ovens
Zanussi double oven switches off during cooking. It can be restarted without a problem so fault can not be detected. It displayed error 3 message once.
Dec 02, 2010 | Zanussi Ovens
Could you tell me what error code 003 is for a zanussi zbd 903 built in double oven
This code is displayed when the user attempts to restart the appliance after an
error code 001 or 002
- Safety circuit malfunction
001 if the meat probe is open circuit or the temp of the food is over 100deg c
002 is if the meat probe is short(closed) circuit hope this helps
Jul 11, 2010 | Zanussi Ovens
I have a Zanussi oven without a manual. It has a rectangular screen with 9 buttons below it. It has numerous symbols for cooking and I have no idea what some of the symbols mean. Can anyone give me a...
I can tell you what the buttons are for but really you may need to get in touch with your local dealer or Electrolux to either get a hard copy or download one from their website.
Starting from the left is your main power button.
Then the oven function button.The next one is the fast heat up/defrost function.Next is the temp. control/current temp.Next the two with + and _ control time or temp.Next is the minute minder.Next is cooking time.
Finally the last one inicates end of cooking time.
May 03, 2010 | Zanussi ZBQ965 Electric Single Oven
Turbochef toaster oven cc temp on warm up only 265 deg ir 465
Dec 12, 2009 | TurboChef TORNADO Electric Oven
Ovens Logo
79 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
