Question about Toshiba TDP XP2 DLP Projector
Toshiba xp2 projector overheating
The fan is running, but overheat indicator button goes on after less than 15 minutes. The display also goes blank almost immediately, giving me no opportunity to shut down my programs.
  • Rudra Feb 22, 2012
    I have gone in to the menu and increased the fan speed from Normal to High. This did extend the time the projector runs by about 30 minutes before shutting down.
    I have heard that adjusting or replacing the heat sensor may solve the problem, but I don't know where it is located.
    I have not been able to find a technical manual online, although I do have the owner's manual.
    Thanks in advance!
  • 3 Answers
Better late than never for any other XP2 owners out there. I've gone through 1 lamp so far with very good results. The key to overheating is cleaning the fan out, i.e. it sucks in a lot of dust particles over time which accumulate on the fan blade and in the vents blocking good airflow. Take a good strong vacuum hose to every vent, then again right when you turn it on. This will get the fan up to speed quickly and assist with removing more dust internally. Eventually, you'll need to open the projector up and clean internally (carefully), but doing the above maintenance will prolong its life and extend the lamp too!
Posted on Dec 10, 2014
5 Suggested Answers
SOURCE: Toshiba TDP S8 projector shuts down suddenly
most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
SOURCE: toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Posted on Nov 12, 2009
  • 6 Answers
SOURCE: I have a Toshiba TLP 260 Multimedia Projector
If all the fans are running and you are sure, than it sounds like you have a bad main control board. Double check that all the fans are running. If so you will need to replace the main controller, this is the board that the fans are plugged into.
Thanks the Projector Guy
Posted on Apr 21, 2010
AJIN G
  • 6694 Answers
SOURCE: We have Toshiba TDP-T05 projector - recently
Before going to by a new one just try to do the following
First of all try to reset the lamp hour of your projector. For resetting the lamp hour do the following.
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on,
Otherwise Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projecto and watch.
ok
Posted on Mar 07, 2011
I'm having a problem with my Actros mercedes truck V8 cylinder is overheating when you drive long distance what are the main courses
The thermostat may be stuck closed (should overheat in 10-15 minutes, maybe less if you are driving in hills or with heavy load).
Otherwise, your fan many not be working. The fan should definitely start before it overheats and it should be running when it is in an overheat condition. Fan is on the back side of radiator.
May 17, 2015 | Cars & Trucks
Service manual
It is not working for Toshiba TDP-XP2, when I hold three button above and plug the power on, the light at power button is blinking forever.
Any help will appreciated.
Apr 04, 2012 | Toshiba TDP XP2 DLP Projector
The cooling fan stop working on my Epson EMP 700 Multimedia Projector, can I get a replacement part and replace it myself?
The temperature indicator is red.
The projector is overheating, which turns the lamp off
automatically. Let the projector cool for a few minutes,
then turn it back on. Make sure nothing is blocking the
ventilation vents.
If the projector continues to overheat after you clean the air
filter, the problem may be caused by damage to the cooling
fan or internal circuits. Contact a qualified service person.
ยจ Warning: Do not attempt to service this product yourself except
as specifically explained in this User's Guide.
Representative : EPSON AMERICA, INC.
Address : 3840 Kilroy Airport Way
MS : 6-43
Long Beach, CA90806-2469
Telephone : (562) 290-5254
Jan 17, 2011 | Epson EMP 700 Multimedia Projector
I have a Toshiba TLP 260 Multimedia Projector --after a couple of minutes of being on the fan icon appears in upper left corner the projector will shut down indicator lights for the fan and on, goes red. ...
Apr 21, 2010 | Toshiba TLP 260 Multimedia Projector
My Acer PH530 overheats and shuts down after 15 minutes.
Mine does the same. When it was still under warranty I kept sending it in to get it fixed, but Acer never fixed the problem (rather they caused more problems). I sent it in for repairs 4 or 5 times, but eventually the warranty expired (after they told me they would extend it from the dates of the repairs). I haven't found a solution. If you do please let me know. Anyway, I don't recommend this projector to anyone else. AND, I certainly don't recommend Acer's customer service. Their warranty is worthless.
May 08, 2009 | Acer PH530 DLP Projector
Infocus IN1 Gaming Projector
Hi, I just bought the same projector Infocus IN1 and after just 15 minutes of use it turned off due to overheating. It seems that the lamp is very ineffecient and produces too much heat. The ambient temperature in the room is only 16 deg. celcius.
The solution I came up with is to have a standing fan blowing air directly on the back of the projector from less than a foot away. The standing fan which we usually use here in summer was enough to keep the projector cool. The infocus IN1 did not switch off for the next 2 hours (the entire length of the movie), until i turned it off myself. I am not sure how this system will fare in summer when the room temperature reaches 30 deg. celcius.
Oct 21, 2008 | Compaq Microportable 2810 Multimedia...
Projector keeps turning off
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Aug 07, 2008 | Dell 2300MP Multimedia Projector
LCD PROJECTOR GOES BLANK
Check the cooling fan/ air ducts - sounds like it's overheating and shutting off to prevent damage.
Mar 12, 2008 | Computers & Internet
Toshiba TDP XP2 DLP Projector Logo
129 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
