Question about E-Machines (308714) Motherboard
Searching for a wiring diagram for my E machine....
I bought a new case, power source, and will be adding a few drives, i'm searching for a basic wiring diagram for the power, audio, and usb port wires
  • Benjamin Jeffrey
    Benjamin Jeffrey May 11, 2010
    Hello! I'm here to try my best in assisting you with your problem. Most diagrams for computer wiring will be completely different because different motherboards are arranged differently. What kind of Motherboard will you be using with your computer?
    Scholar:
  • 172 Answers
Industry Standard Architecture exists here.
The pin arrangements for USB are standard, some usb headers are attached to the boards in the opposite direction but the pin arrangement is the same.
USB headers consist of 9 pins, arranged as 4 pins and one missing, and 5 pins like this:
x x x x o
x x x x x
these are marked as:
vcc1 usb 0- usb 0+ n/c
vcc2 usb 1- usb 2+ n/c
colours are:
red, white green black
Note: some motherboards have these connectors back to front but the connection sare as per the diagram
the audio header is arranged as follows:
X X X O X
X X X X X
top row = gnd, vcc5, mic2,n/c line
bottom row = mic1,mic r, line out,front spk r, lin out L
The cable colours may differ but the preformed plug will only fit in one place /direction
Posted on Dec 01, 2008
The emergency lights keep blowing fuses as soon as a new one is added. Previously worked fine
What make , model an year vehicle ? You have a short to ground , would need to look at wiring diagram to see what all is on that fuse . You can go on youtube an check out some videos on how to find a shorted circuit . An watch a few on basic electrical trouble shooting . You can find free wiring diagrams at http://bbbind.com/free_tsb.html
Feb 13, 2016 | Cars & Trucks
In Need Of Wire Connection Diagram of Jumpers, Power Source, & SATA Cables/Cords
Ron ,you write the drive,i suppose you have one drive.C\drive.if you removed C\drive and replaced it with the new drive you have to have the WINDOWS INSTALLDISC.you can't change C\drive all windows files are on it.there of BOOTFAILURE.solution put back the old drive.if you want moore space you have to buy a new disc.windows install DVD.
May 12, 2013 | HP Pavilion a1230n (EG134AA) PC Desktop
Yamaha RS100 wiring diagram
Hi, Imanazing for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "Free" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha RS 100 wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
YAMAHA RS100 RS125 SERVICE MANUAL WORKSHOP MANUAL eBay
Yamaha Rs100 1976 Usa parts lists
Yamaha Corporation RS100 Owner Manual
Apr 02, 2011 | Yamaha Motorcycles
What specifications do I need when identifying a suitable replacement for my power supply? Its in a Gateway 830 GM desktop computer
The load is one thing, like how many watts does it supply. You'll want that or higher in the new one. Just as important though is what is the new power supply compatible with. Some name brand machines made theirs with unique dimensions so that only theirs would fit in the case... If you have a standard size case, then you're probably good to go. Look at the plug for it, there are two bundles of cables in some, and the plug type. If possible, checkout the tech specs on the model on the Gateway website and that should give you the basic info you need for searching on a replacement.
:o)
Jan 02, 2011 | Gateway 830GM power supply **FREE **...
I have a 1994 toyota celica,passenger side electric window has stopped working,without a wiring diagram,cannot find where it is supplied from or if it is has a fuse or a relay,all fuses ican find seem good
before you start searching there. open up the door and test if the motor works by connecting it directly up to a 12v source
no point searching for bust wires or fuses when it could be the motor.
Sep 18, 2010 | 1994 Toyota Celica
Philips FW 780 v Set Wiring Diagrame
Please will you indicate the problem so that we can go by the present issue. Within the electronics side specify whether it is power side, the drives,or the optical.
Feb 27, 2010 | Audio Players & Recorders
Emachine optiarc dvd rw ad-7200
try to go for sony rewrittable dvd and then go nero for burning it bro still i u have problem then moment while ur inserting ur dvd u will get ur option like burn the dvd and open and view the folder ok then go for it to burn the dvd
Mar 01, 2009 | E-Machines eMachines Refurbished EMA...
Philips CD6451B/37 Cordless phone w/Answering machine-NO BASE FOUND-SEARCHING
Try changing the battery. Try using a new AAA rechargeable battries.
Oct 23, 2008 | Philips CD6451B/05 Phone
Searching for wiring diagram
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=420817e4b66b5093026515350edf12d2&q=Raymarine+Apelco+6760
heres the link to download manual it will have wireing diagram in it for you also i will be uploading the manual to fixya
May 20, 2008 | Computers & Internet
Can't see other PC's on my network with Microsoft Vista basic
set up file sharing and make sure the laptop is set to "private" not "public" in the Networking and Sharing Center.
Nov 20, 2007 | Microsoft Windows Vista Ultimate Edition
E-Machines (308714) Motherboard Logo
344 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
