Question about Simpson Washing Machines
How do i change rubber bellow in simpson 45s558e washing maching
dauphine
  • 207 Answers
SOURCE: Simpson Ezi Loader 5.5kg 45S558E
I'd say that belt might be loose a bit so it slips under load. That would explain why the motor can rotate empty basket but not the loaded (heavy) basket.
Posted on Apr 20, 2008
codfish124
  • 36 Answers
SOURCE: Changing a rubber boot
there is a spring around the boot front with a wire remove it then on the right side of the tub there is a clamp loosen it and take off the boot and put the new one back in
Posted on Dec 13, 2008
  • 13 Answers
SOURCE: bosh washing machine door rubber bellows are
are these stained like a black mould?
Posted on Jun 06, 2009
  • 69 Answers
SOURCE: Simpson washer 45S558E manual needed
You should be able to download from www.simpson.com.au, click on "downloads", then click on "manuals" on the front load washers section. However, I just tried this, and there seems to a broken link on the website. You can contact the Simpson Help by clicking on "FAQ's", which has an email link to customer service, as well as a customer service phone number. Maybe the faulty manual link will be repaired in the near future?? Good Luck!!
Posted on Aug 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: no start,the door interlock is just making a knocking sound.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
How do I reset my simpsons eze loader 5.5fkg front load washer 45S558E.. have installed a new LOCK DOOR part
turn off the mains hold power on
turn on the mains plug
have you tried holding in buttons and turning on the mains
wait a min??
perhaps it wont lock the door because of a connection fault
the controller is detecting your closing the door
next in the routine is usually start to detect motor and add water
perhaps the intake valve has failed and the machine isnt detecting water...?
Dec 09, 2014 | Washing Machines
My simpson eziset 7.5 washing maching does not hold water
Be sure that the drain line is above tub level.
Dec 04, 2012 | Simpson Washing Machines
Error code df on a simpson washing maching
The clue is in the water temp. light flashing. DF means that the temperature sensor is faulty. Replace it with a new one. Turn power off at wall. Remove the 3 screws & open panel. Sensor is plugged onto control board near the middle top of board & goes down into the base of the control panel at the middle where the water enters the machine. Unplug from the board taking care not to damage the pins on the board. Replace the new one making sure the o-ring is on it. Close up panel & turn power back on.
Oct 15, 2012 | Simpson Washing Machines
WashMachine wont wash and wont stop filling
There is a rubber tube that goes from the outside of the outer plastic bowl up to the pressure switch in the top panel. It is on the left rear corner. It may have been pulled off the pressure switch. Look under on that corner and locate where it is attached to the plastic bowl. if that is OK then follow the tube up and check top connection.
Hope this will help you.
Feb 07, 2012 | Simpson Washing Machines
The washing maching was working. Then I smelled
need to replace the rubber ,the one who moves the motor under the bolt
Sep 17, 2009 | Washing Machines
Simpson Washing Machine -showing df error
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 22, 2009 | Washing Machines
Aug 09, 2009 | Washing Machines
Simpson Ezi Loader 5.5kg 45S558E does not complete a cycle when loaded with clothes. Will complete a cycle when no clothes placed in drum.
Apr 20, 2008 | Washing Machines
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Whirlpool duet water leak
Open your wall faucet to full pressure to stop the drip. If this does not work simply change the inlet valve of the machine which is at the top, where the water enters the machine. You can do it yourself. And rate me plz if helped.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Nov 10, 2007 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Simpson Washing Machines Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
