Question about Kenmore 64802 Top Freezer Refrigerator
Temperature My older refrigerator freezes my vegetables.I don't know why. I don't even know how to adjust the temperature dials. Please tell me which number on the dial represents colder or warmer? I don't know, for I got it second hand. The freezer works fine. It has a separate dial. I don't know how to co-ordinate the two dials. Could this be another problem unralated to how the dials are set? Is there a phone # I could call? Tatjana Johnston TatjanaMj@hotmail.com
  • TatjanaMj Nov 21, 2008
    Thank you for your advise. My freezer temperature was set at about 8, and kept things nice and frozen, but my fridge lately froze vegetables even set at 2. Someone said unplugging and letting my fridge sit to defrost all the lines for a day or two might help. Do you agree? I have done this. A little water drained from it. I plan on plugging it in again and setting the freezer temperature at a little lower. Would this help the fridge temperature be warmer? I intend to follow your advise and measure the fridge and freezer temperatures. If this works, I will have a good second fridge, since I ended up buying a new fridge a week ago. Tatjana TatjanaMj@hotmail.com
  • andrewbewsfo Dec 24, 2008
    Not sure if I need to turn the dial on the fridge to higher numbers or low numbers to make it cooler?
  • 833 Answers
Lower numbers are warmer temps.  Get an outdoor thermometer and put it in the fridge.  It should read about 40 degrees F if you've left the door closed for an hour or so.  Don't worry about the freezer too much.  It should be at 0 F or so.  Generally, leaving the settings at 2 or 3 is right on most units.
Posted on Nov 20, 2008
How can I get into the cut-on settings of refrigerator
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this help in solving the problem....
May 12, 2011 | Refrigerators
How do I regulate temperature
I hope this will help in solving the problem.......
May 09, 2011 | Samsung RF265AA Bottom Freezer French Door...
How to set up the temp. please
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
Our Amana AF12538 AE Refrigerator is causing the vegetables in the vegetable bin to freeze. What could cause this? the Units is only 2 years old.
Refrigerator temperature control set too cold or faulty Fresh Food thermistor.
Adjust refrigerator temperature control or check thermistor.
1 Refrigerator section too cold
2 Refrigerator airflow not properly adjusted
3 Check air flow.
Just too much information for this page. If you would like the long version please let me know. I am a Technician and have the tools and the answers if you would like my assistance. I will go out of my way to help you and would rather tell you this first so please do not rate unless I assist you Thanks, Sea Breeze
Dec 30, 2010 | Amana AFI2538AE
The lettuce freezes even when we dial the control to 45 degrees. Please help
#1 Does your lettuce freeze in the crisper drawer? If so this would be your thermistor located behind the temperature control knob. At the very top inside the top cover is where it is located. It looks like a device with a wire covered in plastic that reads your temperature and allows your refrigerator to cool evenly. If your lettuce is not in the crisper drawer than this can also freeze your vegetables and dry them out. I hope I helped you.
Sep 02, 2010 | Maytag MZD2766GES Side by Side...
Vegetables are freezing inside vegetable bin
Most likely your refrigerator is set at too cold a setting. Just turn the temperature adjustment to a warmer setting.
May 03, 2009 | Refrigerators
Freeing food in refrigerator, even vegetables in vegetable tray
You have 2 dials in the refrigerator. One is the thermostat setting the cold temp in the freezer, the other is a damper that allows cold air from the freezer to the refrigerator. Set the thermostat to the middle then try closing down the damper, most say colder or warmer refrigerator. If the damper is closed and your refrigerator is still freezing, then I would guess that the thermostat is bad. A thermostat runs about 40 to 60 dollars wholesale. Retale should be about double.
Oct 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Beko LF320 temperature dial numbered 1 to 10 which way is coldest?
Right to the point people. ok to make it warmer, it is the lower the number
thanks and go night ;)
Oct 01, 2008 | Refrigerators
Kenmore 64802 Top Freezer Refrigerator Logo
213 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
