Question about Vizio P50HDTV20A 50 in. Plasma HDTV
No sound, no picture
Worked in the morning. Daughter was trying to figure out how to connect her laptop to view on tv. She plugged a cord into the service port, the tv went off, unplugged the cord, the tv came back on. Called cable company to ask about viewing internet on our tv and the tv wouldn't turn back on. If you unplug the tv and plug back in you hear it click on. The screen looks a little lighter and you can hear it like it is on, but there is no picture, sound or anything. The power light button isn't even on. You also can't turn it on or off with the power button. Nothing happens. Been told it may be the bulb. Don't know what to do next. Out of warranty.
  • Cheree Chabot Feb 23, 2012
    I contacted Vizio. I told them that we plugged into the service port. Was told I most likely fried the tv. Don't think I will even bother having a repair service come out. Have always been partial to plasma. Any suggestions on plasma vs. LED??
  • Cheree Chabot Feb 25, 2012
    Yes, we are having our plasma tv repaired. Costing $500 though. Of course about half of that is labor. Note, don't ever touch the service port!!!
    Sergeant:
  • 302 Answers
Hello sorry to hear that. From your description it sounds like your signal board may have been damaged by you plugging in your laptop to it. The signal board is the one with the tuner on it.
Posted on Feb 23, 2012
    Scholar:
  • 73 Answers
My darling husband is set on LED tv.best wishes...hope he doesn't see your post and get's a bright idea on how to get a new tv in the house! :-)
Daughter got Asus K52J laptop for Xmas. All was fine but this morning/ inbuilt mouse is not responding, any ideas
disconnect all the external devices connected to the computer
remove the power cord from from the computer
remove the battery from the computer
press and hold the power button for 10seconds
after that reseat the battery and plug in the power cord
turn on the laptop
the issue will be fixed
Thank you
Jan 06, 2011 | Computers & Internet
Sound quit working
Unplug power cord from outlet for 20 minutes , then plug back, this will reset tv
Mar 28, 2008 | Philips 14MS2331 14" TV
I have great sound on my tv but there is no picture
i had the same problem take the back off an unplug the lcd an give it a blow put bit all back together an fany's your ant
Apr 24, 2010 | Sanyo DP37647 37 in. LCD TV
My TV worked fine this morning,Turned it off,Went back to put it on and now it won't turn on at all,Why?
Maybe faulty power switch or its blown a fuse or the powwer supply inside the TV is kaput.
If its out of warranty get in touch with a reputable TV mechanic and ask them to come and repair it. It might be good to get a ballpark figure on how much it's going to cost.
Good Luck
Sep 13, 2009 | Sanyo DS35510 35" TV
Color bars only on KWorld PC to TV - Composite and SVideo
found this reference it may be of help
This product appears to be defective. I connected it to a working video camera that produces an excellent picture on a standard monitor. I looped the video from the camera through the monitor to the converter which is connected to a new ACER LCD display. The LCD display workes perfectly when connected to my computer. Using the converter, the results are poor. You can see the desired picture in the background but in the foreground there are horizontal bars that scroll vertically through the picture. I'm returning it for an exchange - will try again.
Jul 26, 2009 | KWorld PC to TV (0872880887527) Video...
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Connect my laptop to tv with a sound
Your computer may have come with cables to do just that. If not, you have options:
For video, I would check your TV inputs to see if it has a VGA port, since that would be the easiest. You can also get VGA to RCA or S-Video converters online as well if your TV does not have a VGA port. Almost all TV's these days have RCA inputs.
For audio, you can get a headphone jack (3.5mm) to RCA converter.
If you can't find the converters at your local electronics store, just google VGA to RCA and headphone to RCA.
Once you have the necessary cables connected to your TV, your computer will recognize that it has been connected to an external video source. I'm not sure, but I think it is either key combination Fn+F6 or F7 to perform a monitor switch. You can also right-click on the desktop and select properties (or personalize in vista). Then switch to the settings tab (or Display settings in vista) and click on the alternate display.
May 03, 2009 | Sony VAIO VGN-FE550G Notebook
Television has sound but no picture
Check the cables first that connect to your video device, are they in tightly?  Test the cables on another TV to make sure they haven't gone bad, which is common.  Also check the input selection on the TV to make sure it matches with the video input the cable is connected to.
Dec 06, 2008 | Philips 50PFP5332D 50 in. Plasma...
Vtech kidizoom camera
We had the same issue. After turning on, nothing on the view screen and the buttons didn't work. The camera could turn on, the turn on screen and sound happened and we cold turn off (show off screen and sound)...even after changing batteries. It was like that for a week.
I found it had to do with TV connector slot. Thinking back, my daughter had been playing with the TV connector right before it stopped working. I took a small hair pin and put it in the TV connector slot, lightly wiggled it and the camera sprung back to life. I'm guessing the camera hardware was acting like it was still plugged in...hence turning off the view screen.
Anyways, hope that helps someone.
Jul 25, 2008 | Vtech Kidizoom Digital Camera
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
312 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
