TV was turning off and on. Finally stayed on but no sound.
Was also having toruble connecting to satellite
    Sergeant:
  • 302 Answers
Sounds like a problem with your main board. The main board is the one with the tuner on it. You can get parts for flat panel tv's at www.interliquidparts.com
Posted on Feb 23, 2012
Testimonial: "I took the TV to a local repair shop. The problem was a defective capacitor in the power supply. Thanks."
Hi how do i connect a sound bar to my 43 in tv
Depending on the sound bar / TV configuration you can have various connection solutions.
The usual connections are HDMI, RCA and optic. Whichever route you take, consider what you want to achieve. For instance, I have a sound bar connected and use satellite as my TV source. Instead of connecting the sound bar to the TV, I opted to connect it directly to my satellite receiver as my receiver has this option. The reason I did this is so I can tune my satellite to a music station and play music through the home without having the TV on. No point of running the TV is all I want is sound.
G'luck!
Jun 16, 2016 | Seiki Televison & Video
No sound
Sounds like a loose connection that has finally failed in the audio out circuit
Jun 04, 2008 | Hitachi 61HDX98B 61" Rear Projection...
Got issues with some kind of background noise that suddenly shows up after some minutes of use... Its some kind of a buzzing sound, that appear once a while and stays there until i turn the sound off.
There are a few things that can cause this kind of sound through your speakers. First off, your cable wire. If it's not attached to the subwoofer, remove it and try a different cable. It could be that a piece of the wiring inside the cable has been damaged. If this doesn't help, your next bet would be to check the sound card inside the computer. Try plugging in a different pair of speakers or some headphones. If you still hear the buzzing sound your sound card needs to be repaired or replaced. Finally, you could have some electrical interference caused by certain devices like a cell phone or your TV. Try turning the devices off and see if the buzzing sound is still being heard.
Dec 26, 2010 | Creative Technology Creative Inspire T3130...
Most of the time I switch between inputs on my Vizio the sound turns off. It seems to be related to switching between HD and non HD formats. Is there anything I can do to solve this issue?
Hello.
If sound turns off for a couple of seconds it is actually not an issue but normal operation. When you switching between formats different software protocol is in use and it need some time to synchronize.
In case if sounds turns off and stays off you have to make sure where this problem is originated.
If you have DVD player with both standard and high-definition outputs - connect them both to the different TV inputs and switch to see if problem is still there. If sound comes back while using DVD - you might have problem with your cable/satellite box and TV has nothing to do with it.
If DVD "test run" creates same issue - main board in your TV have to be replaced. Vizio have many software/firmware - related issues.
Regards.
Russ.
Dec 01, 2010 | Vizio 42 in. LCD TV
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
Set is connected to a DirectV satellite box. When the system is turned on, the TV starts up normally but then shuts off after 12-15 seconds. The pilot light on the front stays on, but there is no picture...
your technician indicated there was a problem in the "horizontal deflection circuit" and that a local TV terch s/b able to fix it. I have a tech visit scheduled for Thursday.
Oct 05, 2009 | Televison & Video
Does not pick up cable satellite signal
Do you have the satelite hooked threu the regular cable input? If so hook it thru one of the video inputs instead; composite video or component video. the picture and sound will be better and you will be by-passing the problem area of your Tv ( the tuner).
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture, sound OK...setup menu shows up, able to get picture in PIP
You will need to check the inputs on the television. You more than likely have a bad video in signal. This can be a bad cable or a loose connection either at the input of your television or at the output from your receiver, (cable or satellite). First, try wiggling the cable and then try replacing it. This should fix the problem. If not, your signal may be routed through a stereo or other switching device?
Apr 17, 2007 | Samsung PCL541R 54" Rear Projection...
Television takes 6-8 times to start up or turn on
Sounds like you may have cold solder connections. Call a pro to assist in this repair. Good Luck
Aug 03, 2006 | Philips Magnavox MS3252S 32" TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
