Question about Mitsubishi WD-73732 73" Television
I have a dlp 73in mitsubishi tv and i have sparking in the long box next to the bulb housing
Bulb went out and replaced it, did have the wrong bulb in it before but did work replaced it with right one went to turn it on and the clicking began and picture will not come on and shuts off after a min
  • Mitsubishi Master
  • 8,617 Answers
Check to see if the lamp connectors inside the lamp compartment didnt get pushed back inside the set. If they are still there secure inside the lamp compartment then you will need a new ballast which you can get from www.tvrepairworld.com
Posted on Feb 23, 2012
techman
  • 3130 Answers
SOURCE: Mitsubishi WD 73727 73in
Contact Mitsubishi with the proof of this and demand a new TV set. Maybe it is the service shop causing this, your warranty should also be extended for the time you were out of the use of the TV set while waiting for parts. If this does not work, the state attorneys office should be able to get you a new set or at least this one repaired. Good Luck
Posted on Sep 27, 2007
style_points
  • 34 Answers
SOURCE: Mitsubishi WT-42311 DLP Bulb Replacement
Your access should be a a panel near the back or side. You will see that it is somewhat easily removed and should have maybe one or two screws. You will see the casing to the lamp. Go ahead and remove it. Now unscrew the old bulb and replace it with a new one. There is not a lot of screws holding it together. It's a fairly easy process once you find the lamp. You should see the lamp once the panel is removed.
Posted on Apr 27, 2009
  • 668 Answers
SOURCE: mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Posted on Oct 26, 2009
  • 8457 Answers
SOURCE: MY PICTURE IS GETTING DIM,
Yes,the tv projection lamp life are ending.Replacing the tv projection lamp will solved this problems.
Posted on Jan 24, 2011
  • 84 Answers
SOURCE: I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Posted on Mar 09, 2011
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
What is wrong with my Mitsubishi Tv model WD-65638
Youre lamp has failed. you need a new lamp.http://projectorlamps.com/mitsubishi-dlp-tv-bulbs-915b441001-pvip.html 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi WD Televison & Video
My replacement bulbs keep burning out within 30 days. I took a closer look and there is a small square piece of glass that sits next to the lamp housing. It looks as if the light from the lamp goes through...
Something is definitely wrong if you are consistently only getting a month out of a bulb.
Either something is overdriveing the power to the bulb (unlikely) or there is a vibration or something is intruding on the bulb itself.
Good luck and let us know what you find on this.
Jan 08, 2015 | Mitsubishi WD-57732 Projection Television
Mitsubishi dlp tv won't turn on
My family's house once had a older model Mitsubishi DLP TV that went out (which I found out they are famous for). The problem was the projector bulb had died. Your problem is either that or a ballast problem (something more complicated that I do not know how to solve).
Open up the bulb housing on the back of your TV and check to see the condition of your current bulb. NOTE: the bulb housing contains mercury so handle with care. Also, if the bulb is broken/dead, there might be shattered glass sitting inside the bulb housing.
The only way to fix it was to buy a new bulb (search amazon for wd-65837 lamp" you will find a few results). This temporarily fixed our problem. However, for some reason, the aftermarket bulbs do not last anywhere near as long as the original one. So if you do end up buying a replacement bulb, buy something with a good warranty. If this doesn't work just send the bulb back.
Hope this helps!
Nov 10, 2012 | Televison & Video
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-73732 73" Television Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
