Question about Nikon Cameras
I formatted my SD card on my PC, which I should have. I am trying to reformat the card on my Nikon Coolpix L15, but it freezes and shows a black screen when ever I select set up. Is there anyway for me to reformat my card, or is it toast?
  • verbose Oct 28, 2008
    Ah, no dice. Thanks, though!
  • 79 Answers
Hi there
if you fomatted the card on your p.c. it may have done it in the ntfs format which the camera doesn't understand. try re formatting the card on your p.c. but select the fat32 option.
its a long shot but try it anyway.
hope this helps
beergut707
Posted on Oct 28, 2008
Images will not transfer to PC via USB or SD card
This reason might be because of Virus in your memory cards the best option is.. try formatting the memory card or use different SD card, and reset your camera settings
Apr 20, 2015 | Nikon Coolpix S3000 Digital Camera
Nikon coolpix copy button will not work
Make sure the SD card is not set to protect with the small slide switch on the side of the card, then try formatting the SD card NOT the internal memory.
Jan 27, 2013 | Nikon Coolpix 4100 Digital Camera
I bought a used nikon coolpix and added an 8gb card for it but it says there is no memory available even though i already formatted it
Try reformatting the memory card using the camera go to the camera's Menu and select format memory card.
Dec 13, 2012 | Nikon Coolpix 5400 Digital Camera
THIS CARD CANNOT BE USED
Try reformatting the memory card through your camera, normal under menu or options.
If not you may have a different format kind of memory card such as sdhc versus just sd and you camera may not support it
May 26, 2012 | Nikon COOLPIX L10 Digital Camera
The camera keeps showing the same message '' memory card is write protected'' I can not use the camera because of this, also when I go to reformat card it passes over that so I can't reformat the card :-( ...
Remove the SD or SDHC memory card from the camera. Look at the front of the card, on the left there should be a little slide with an arrow pointing down that says "Lock". The slide should be in the "up" position.
Nov 27, 2009 | Nikon COOLPIX S200 Digital Camera
Camera does not show taken ( saved) pictures
problem is in memory card...i think. try with cleaning memory card contacts. use pure alcohol and small piece of cotton to clean dust or other dirt. if this not help, try some card reader to transfer images from camera to PC. try also with some other camera. it's possible memory card is damaged and you can't do nothing. try reinstall nikon software on your PC.
Feb 19, 2009 | Nikon Coolpix L15 Digital Camera
Nikon Coolpix S1 won't read card.
I am confused. If you can FORMAT the SD card when it is in the camera (FORMAT is successful) you SHOULD be able to use it.
Mar 29, 2017 | Nikon Coolpix S1 Digital Camera
SD Card not readable in Nikon Coolpix S1
Try to reformat the card from your MAC.
Apr 26, 2008 | Nikon Coolpix S1 Digital Camera
Sd card
To reformat the card so the Nikon Coolpix can use it you can use the DOS command 'format' e.g. format g: HOWEVER the default DOS format is FAT32 which the Coolpix will not read. The SD card needs to be formatted in FAT.
Open a DOS command window and type:
Format 'volume' /fs:FAT
Where 'Volume' is the drive letter to be formatted. On my PC this was 'G'. This may be different on your PC. Make sure it isn't an internal drive e.g. C or D!
e.g. format g: /fs:FAT
The card then works OK on the CoolPix
Nov 27, 2007 | Cameras
Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Mar 13, 2007 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
60 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
